Random throttle inputs at idle
Old Oct 4, 2023 | 02:57 AM
marker223's Avatar
marker223
I just turned over 250K miles and I couldn’t be happier with my truck. It’s given me very few problems over the years.
Recently something strange has been happening. I believe it happens only at idle. The rpm’s will surge as if I’m blipping the throttle. Sometimes the increased engine speed will stay increased, sometimes it drops back to normal immediately. The rpm’s haven’t gone over 1,000 that I’ve noticed. Usually the increase is a few hundred, maybe up to 700-850. It does it when the transmission is in both Drive and Neutral.
If I’m at a red light and it starts acting up I will put it into Neutral so I don’t accidentally bump into the car in front of me.
Once I’m on the throttle intentionally the symptom stops completely.
I also notice it happening more when the temperature outside is hot. Not sure if this means anything because it’s always hot here in DFW.
Any ideas?
2006 F250 Dealerproofed by Powerstroke Specialties at 165,000.
I’m going to call Mr Hewitt tomorrow and run it by him also.
Old Oct 4, 2023 | 02:54 PM
Jokester00's Avatar
Jokester00
Sounds like classic ICP sensor/Pigtail issues.
What is your ICPv, ICP, IPR% KOEO and when the issues happens?
-jokester
Old Oct 4, 2023 | 03:33 PM
marker223's Avatar
marker223
I cannot get any of that info at this time. My house was significantly damaged in a fire just shy of 2 weeks ago and my laptop was in the house.
Once things are kinda back to normal I’ll get that info. It might take a while.
johnfl
General Automotive Discussion
Nov 5, 2023 09:39 PM
cprdnick
Aug 24, 2008 09:51 AM
loufres
May 21, 2007 08:32 AM
XFACTOR
Aug 27, 2005 09:10 AM
