Camper Gas Explosion
Old Sep 30, 2023 | 09:04 AM
HRTKD's Avatar
HRTKD
https://www.foxnews.com/us/couple-sc...urns-dangerous
I'm scratching my head on this. Perhaps the explanation in the article isn't worded right or I just don't get it.
In related news, I had my RV 30 lb tanks recertified this week. One was full, one was empty. They checked the full one and said it was overfilled and bled off some of the gas before they proceeded with the recertification.
Old Sep 30, 2023 | 10:25 AM
WE3ZS's Avatar
WE3ZS
That is one of the most poorly written news articles that I’ve read. All of that talk about propane gas tanks exploding then showing a photo of the camper’s 2 tanks looking perfectly fine (and still connected!)
Old Sep 30, 2023 | 07:16 PM
memilanuk's Avatar
memilanuk
It's about as poorly written as anything else that passes as journalism these days.
That said, if I had to read between the lines - and there isn't really any choice, given the spastic manner in which the writer jumps around - I'd say they left the valves open on the propane bottles in the tank compartment (fairly normal, I'd think, especially overnight) and then someone left either a stove burner or the oven on. All too easy to do, with some of those ***** turning when you even brush up against them in the tight confines of a camper. Gas probably settled low, unnoticed, until at some point in the night the furnace (also down low) kicked on... and pop goes the weasel at that point.
Old Oct 1, 2023 | 02:03 AM
greenno's Avatar
greenno
Leaving the valves all the way open with no fitting at the connector will cause zero gas to flow. The internal seal has to be pressed in by the hose fitting, or screwdriver if you need to clear any obstruction.
My guess is they had a gas leak inside the cabin or accidentally left the stove on without sparking the burner and the gas level increased and then ignited when they finally did try to light the stove.
Camper should of had a propane sensor inside along with a CO2 sensor I think thats code if Im not mistaken.
I always leave my tank valve open when connected up in the propane compartment whichever one I am using at the time.
I leave my "spare" tank shut off and not be able to automatically start feeding the system when the first tanks goes empty so I can monitor my usage.
NL makes a quality camper, glad the two individuals are semi ok after that close call.
Old Oct 1, 2023 | 08:50 AM
HRTKD's Avatar
HRTKD
Kind of makes me wonder if there isn't a LOT more to the story. Like the husband was trying to off the wife. While he was hurt, he was outside the camper when it blew up.
Old Oct 1, 2023 | 09:29 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
What I got from it was that a burner on the stove was left on. Yes, if the tanks were turned off then there wouldn't have been a problem, but most folks leave the tanks turned on (unless in storage) anyways.
Old Oct 1, 2023 | 11:51 PM
350Recon's Avatar
350Recon
Seems that they did not get any warning from the detector.
I know my detector is operating when the dog breaks wind at 2:00am and I have to get up to reset.
Old Oct 1, 2023 | 11:58 PM
HRTKD's Avatar
HRTKD
I had a guest in my camper that did that. No more chili for him!
Old Oct 2, 2023 | 12:09 AM
memilanuk's Avatar
memilanuk
I know mine went TU right at the 5 year mark that they are rated for... started chirping and no amount of resets would shut it up. When I replaced it, I seem to recall I replaced it with a combi CO/LPG sensor. For some reason, I thought the original was just a single sensor, but I can't recall which it was.
Old Oct 2, 2023 | 12:27 AM
HRTKD's Avatar
HRTKD
Mine did the same. Single sensor, propane only. New one is a combination. From what I've read, they don't last as long as they used to. The OEM one lasted 15 years. New ones might last five years.
Old Oct 5, 2023 | 07:09 AM
bigwin56f100's Avatar
bigwin56f100
Yea sure, go ahead and blame it on the dog lol
Old Oct 5, 2023 | 09:19 AM
350Recon's Avatar
350Recon
Hehe! That is what I told her.
Old Oct 7, 2023 | 03:50 PM
Winter2's Avatar
Winter2
Propane is heavier than air and so it can build up inside an enclosed space. This happens usually with a boat where the gas builds up in the bilge until it is ignited. It is rare on factory campers as the propane tanks are mounted outside on trailers or in a special enclosure that vents to the outside on slide-in campers. There are safety features with gas furnaces and stoves in campers but they can be defeated or someone can jury rig them for some reason.
With my campers the propane tanks were always turned off while driving and when the camper was being stored. Best to first shut off the gas supply at the tank and to let the furnace or stove purge themselves when the gas supply is exhausted.
barecove
General Automotive Discussion
Jul 12, 2023 01:08 PM
speakerfritz
Apr 28, 2014 12:24 PM
jake00
May 29, 2006 05:36 PM
