Major Electrical Problem/Gremlin NEED HELP
EDIT: Forgot to note that the start trigger wire is not at fault either as the sticking solenoid problem only occurs with the new starter solenoid, the old one has no problems what so ever, but I want to retire it as it struggles to properly engage with the flex plate, resulting in grinding. It is the original to the vehicle, and its quite rusty and doesnt make good connections, especially since the starter terminal is melted from loose connection arcing, and the start wire voltage is verified dead with clutch out and key off so it is not a problem.
Last edited by Ryeguy22738; Sep 28, 2023 at 01:14 PM. Reason: Added extra information at the botttom
Have you been reading post with similar issues ?
I understand your physical challenges.
Do you have access to a typical wiring diagram for the year / model of your truck ?
Do you have electrical test equipment ?
Put the meter on the battery itself and get someone to try and crank it. You did this before and got 3 to 5v on the battery and figured it was bad. That was a good test. Just sitting there reading the voltage will tell you nothing, you have to measure it while trying to crank it over. So do this test again. If the battery drops way down in voltage again, it's a battery problem again. If the battery stays around 11-12v or higher when trying to crank it, then the battery is good.
So if the battery is good, keep the negative meter lead on the negative post of the battery, but move the red positive lead of the meter to the large battery terminal on the solenoid. Try to start it again. If the voltage drops very low when trying to crank it, then you have a connection problem or a corroded wiring problem in the large wire from the battery + to the solenoid. If the voltage stays around 12v then
Move the red meter lead back to the positive post on the battery. Take the negative meter lead off the neg of the battery, and put the neg meter lead on a good metal spot on the engine block somewhere. While holding the red on the + battery post, and the - on the engine block, try to start it again. If the voltage drops low, you have a grounding problem in the negative wire from the battery neg post to the engine block.
Let's say your meter reads the resistance on one of the wires as 0.12 ohms. You would think that was acceptable right? Wrong. If you have 100 amps running through that wire during cranking, and it has 0.12ohms resistance, 100 amps times 0.12ohms equals 12volts. 0.12 ohms would drop ALL your battery voltage in the wire and you would get zero volts going to the starter. Let's say you put your meter on the solenoid, got someone to crank it, and you got 5 volts on the solenoid and it would not start. That means 12 minus 5 equals 7.5v is being lost in the wire or the bad connection on the battery post or clamp. 7.5v divided by 100 amps equals 0,075 ohms resistance. Just that little bit of resistance will keep the starter system from functioning.
Formula used; E=IxR where E=voltage, I=current in amps, R=resistance in ohms.
Pour yourself some coffee or strong drink of your choice and read the following troubleshooting guide. It was written exactly for your present situation:
https://www.ford-trucks.com/forums/1...w-starter.html
Follow the guide and it will pinpoint the exact location of the fault.
For your starter relay, more light reading:
https://www.ford-trucks.com/forums/1...i-mean-it.html
To summarize Proust, make sure you get a top quality replacement. Lots of junk out there, bad right out of the box.
One last bit of unsolicited advice: Put away your jumper cables and/or booster box. With a battery in good condition and fully charged, the starter system should be able to reliably get the crankshaft spinning. If not, figure out why and correct the issue.
You should not have to jump a fully charged battery. It makes for misleading troubleshooting. Jumper cables are for when you're stranded somewhere with a battery that's only partially discharged, just low enough to keep from starting. Once you get home, put away the jumper cables and figure out why the battery was run down so you don't get stranded again. Jumper cables are the equivalent of crutches, for temporary use. If you break your leg, concentrate on fixing the problem versus learning how to get around on crutches permanently.
There are a couple guys on ebay who buy all the remaining stock when an old fashioned parts shop go out of business. They pay next to nothing, price them cheap to move, make a few bucks, and keep a few of the old gals running.
Just a suggestion from a fellow member of the chemo club.
Know your positive and negative points of contact well.
You should have near 14 Volt's charging while running.
The fully charge battery should hold near 11 volts while cranking.
The grounds on west of the Engine Bay can be a real PITA all
way back to the tail-lights. Corrosion messes stuff up, even fuse box.
There was a time when I made my own wiring, especially on the 6 volts.
And Harleys. Sitting out in that there weather is detrimental to it all.
A truck salvage yard is a great science trip to take. I once shipped a
pickup box all the way from Des Moines truck auto yard to reduce the Rust option.
There is a great Truck Aluminum Box outfit in Missouri too. Got the Aluminum flatbed
from Martin shipped to me also.
Also I apologize for not stating that I checked the voltage battery side while cranking too in the last message.
Also I apologize if I am struggling to understand and am struggling to explain or communicate. I haven't been able to sleep for 6 days.
Last edited by Ryeguy22738; Oct 9, 2023 at 04:38 PM. Reason: Added extra information at the botttom
If you get a good reading on the battery while someone is trying to crank the engine then move your meter leads to the battery clamps for the cables. While someone tries to crank the engine what voltage do you get? If you get 1v or something like that, you simply have a bad connection to the battery itself.
