Injector shims
Old Sep 27, 2023 | 02:44 PM
73z28cam's Avatar
73z28cam
Injector shims
Is it possible to create more problems if injectors are over-shimmed by say .001 or .002 ?
Old Sep 28, 2023 | 09:11 AM
knottyrope's Avatar
knottyrope
.001-.004 is the spec
too tight wont fire well until warmed up
too loose timing will be delayed and or not fire at all
Old Sep 29, 2023 | 05:47 AM
73z28cam's Avatar
73z28cam
thanks for the information,
so with clearance at .004 set cold, it would expand when hot and make it harder to start, closer to .001 the better.
Old Sep 29, 2023 | 08:33 AM
knottyrope's Avatar
knottyrope
closer to .004 is better
cold oil is harder to compress/move
Old Oct 24, 2023 | 01:15 PM
carl2591's Avatar
carl2591
.004 to .005 is new injectors according to the guy on ebay that sells shim kits. KIT COMES WITH:
1. Packets of TEN+ .004" and TEN+ .002" (one required per injector) special stainless-steel washers. TO BE INSTALLED UNDER THE ARMATURE PLATE TO INCREASE THE CLEARANCE BACK TO over .004" to .005" (like new injectors)
I am a 77-year-old mechanic that has worked on a fleet of 7.3 Power Strokes for the last 23+ years. ( Kit provider)
https://www.ebay.com/itm/94-03-7-3L-...oAAOSwZuFdjt5p
Old Oct 26, 2023 | 02:00 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Just to be That Guy.
Does oil viscosity play a role here? 10-30 vs 15-40?
Old Oct 27, 2023 | 02:51 PM
udsuth78's Avatar
udsuth78
Well if the guy on eBay trying to sell me something said it then it's obviously true and accurate.
Old Oct 28, 2023 | 03:56 PM
carl2591's Avatar
carl2591
Smile
Never said it was true or right, but he has sold a **** ton and most are happy with results. If u think It's not right then don't buy, till then your opinion is like azzhole, every body has one.
Old Oct 30, 2023 | 08:36 AM
'88 E-350's Avatar
'88 E-350
Yes. I changed from 15-40 to 5-40 and it helped with the cold starts. So.Cal cold, not Alaska cold. From memory it lowered the 'no start/hard start' temperature threshold by about 10 degrees. Some time later I shimmed my injectors to .004 and cured the problem. Most of them were at or near 0 clearance, some were a tight 0. #8 injector looked newer than the rest, it was the only one with measurable clearance. This was at around 430k miles, now at 446k.
Old Oct 30, 2023 | 02:52 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
Likely because somebody threw an injector at a ghost code for #8 contribution test failing.
JimmyRoach
Mar 10, 2022 01:42 PM
Aaron Nguyem
Sep 15, 2020 11:53 PM
johndeerefarmer
Jul 24, 2016 07:13 AM
ltl_jrw
Jun 27, 2011 11:29 PM
