Explorer 5.0L engine specs?
Old Nov 21, 2003 | 12:24 AM
83 Capri 5.0's Avatar
83 Capri 5.0
I know they came with the GT-40 intake and heads but that's about it. Anyone know if the pistons are forged, what other similarities it has with the 89-95 mustang 5.0L.
Old Nov 21, 2003 | 09:39 AM
CobraXP's Avatar
CobraXP
The early model 302 in Explorers (96 and early 97) came with GT40 heads and an external EGR setup. The late 97 and up came with GT40P heads and an internal EGR setup with DPFE.
The accessory brackets across the front are different on Explorers, along with th water pump because of the tight fit (they are smalller and less thick).
The throttle body is close to an 86+, but not an exact swap. The fuel pressure regulator is from the 91+.
The cam was also different - the one in Explorers is tiny (I don't have the exact numbers with me).
Other than that and the PCM configuration, there is not much different - and everything is interchangeable. There are a few other items that have to be different between them (superchargers, etc), but most parts from the 86+ will be interchangeable.
Hope some of this helps - I'll think of more later when I'm awake...
Old Nov 21, 2003 | 10:15 PM
fauxexplorer's Avatar
fauxexplorer
reverse that,96-97 internal egr just like the 89-93 stang
remove the intake elbow,damper,timming cover and water pump oil pan.an exact bolt in for 89-93,the explorer timming cover will work for the 94-95 stang but pump and damper still need changing
the 97 1/4-01 have the p heads and may require different headers
Old Nov 22, 2003 | 12:15 AM
CobraXP's Avatar
CobraXP
Thanks faux for the correctoin - I knew I was too tired to be answering things this morning...
Old Nov 22, 2003 | 06:43 AM
fauxexplorer
no thanks necessary.you work hard.just a simple mis.hope all is well,enjoy the turkey.
Old Nov 22, 2003 | 11:55 AM
83 Capri 5.0
Thanks guys.
Doing a cheap build up on my EFI 5.0L and came across a couple of stangers who have add the Explorer intakes. Finding out about the GT-40 heads is a bonus! Now I've found a complete 96 Explorer 5.0L for sale, it's in good shape, 50,000 miles on it, what is a good price to pay for that.
Old Nov 22, 2003 | 03:58 PM
ford_tr_man's Avatar
ford_tr_man
$2,500 your taling about wrecked right?
Old Nov 22, 2003 | 10:41 PM
CobraXP's Avatar
CobraXP
$2500 would be a good price - if you can get the entire setup - computer and harnesses and all. My personal preference would be a 96 or early 97 Explorer setup if you can get it. The EGR setup and other things are easier to deal with than the late 97+ in my opinion...
But the GT40P's on the later models are a nice thought also...
Old Nov 24, 2003 | 01:34 PM
83 Capri 5.0
What would be a fair price to ask for 96 explorer engine core? (no heads, no intake, harnesses or computer etc...) I am buy the motor but will be keeping the heads and intake, selling what's left.
Thanks for all the info, you've been a great help to me making some buying decisions.
I think the Capri will go 12.90's next year!
Old Nov 24, 2003 | 03:42 PM
CobraXP's Avatar
CobraXP
Once you get everything off, you are basically down to a regular 302 block. I haven't looked into used blocks in a while (just new ones), so I don't know what they are going for anymore...
No problem on the help... that is what forums are for!
mtntop1
Oct 21, 2014 07:40 PM
CSJohnson
Feb 12, 2014 09:31 PM
Gary Atsma
2009 - 2014 F150
15
Nov 12, 2013 01:06 PM
bookpile
Aug 1, 2010 11:45 AM
