Question
Old Oct 21, 2014 | 05:22 PM
mtntop1's Avatar
mtntop1
Question Question
Does anyone know why Ford used such a big upper intake manifold on the 95 5.0L engine
Old Oct 21, 2014 | 05:54 PM
Conanski's Avatar
Conanski
It's not just the upper.. the lower is just as big, but it's anybody's guess why the 5.0 truck motor got a bigger intake than any other 5.0 motor in the lineup and bigger than the 5.8 even. The upside is it doesn't need to be upgraded when building the motor, you could even build a 347 stroker and not need a larger intake.
Old Oct 21, 2014 | 06:00 PM
mtntop1's Avatar
mtntop1
Question
Do you happen to know the valve lash of the 95 5.0L engine.I think it has to be checked with the lifters bled down.
Old Oct 21, 2014 | 07:40 PM
Conanski's Avatar
Conanski
There is no valve lash adjustment on these engines. Never heard of checking it with the lifter bled down either, the only check I know is that the rockers should torque to spec 1/4 to 1/2 turn after all slack comes out of the pushrod.
BaronVonAutomatc
29
Oct 1, 2022 10:23 AM
mtntop1
Jun 19, 2015 08:31 AM
danger-ranger93
Mar 15, 2010 10:53 AM
flareside_thunder
Oct 21, 2007 04:57 PM
iceman7329
Nov 17, 2005 03:54 PM
