6.0 Issue
Old Sep 22, 2023 | 07:44 PM
06kc6.0's Avatar
06kc6.0
1st Gear
6.0 Issue
So I have a 06 f250 power stroke, I have an issue when I will go to wot the truck will go to 3600 rpm and won’t up shift. Vgt spikes to 84% and builds around 25 boost psi. I have a newer kc stage 2 turbo on the truck with custom tunes. The truck is studded and has a egr delete. It does this in every custom tune and in stock tune.
Old Sep 23, 2023 | 03:01 PM
Jokester00's Avatar
Jokester00
What does your EBP and MAP read when this happens?
-jokester
Old Sep 24, 2023 | 12:32 AM
IHateCommieCars's Avatar
IHateCommieCars
Will it upshift during normal driving, not WOT? Does it not upshift into any gears? Maybe the transmission is in limp mode (2nd and 5th gears only). That's ofter an transmission wiring harness issue.
Old Sep 24, 2023 | 12:34 AM
IHateCommieCars
IIRC, the VGT% decreases as you increase boost, so it seems odd that you're maxxing it out on the high end but still getting 25lbs.of boost.
tonecouch
Jul 20, 2019 07:24 PM
JaredC1983
Jan 7, 2015 09:35 PM
dmanshane
Jan 11, 2014 05:41 PM
mxzracer999
Feb 28, 2013 09:57 PM
Rizzo66_82
Jun 27, 2010 08:57 AM
