5 Speed GURUs Need Help
Old Sep 20, 2023 | 04:27 PM
Woodscustom's Avatar
Woodscustom
Hey Guys, I have a couple questions. 1995 Ford F150 I-6- 5 Speed 4x4.
First, What is this? The blue arrow points to a thing and it looks like it's missing a bolt. What is it and what does it do?
2nd Question. I have a substantial leak, it looks like it's coming from the top. Is it the top plate gasket you think?
It's coming from directly above the drain plug. I crawled under there with a pressure washer and got water boarded by my F150, but it's cleaner now .
WC
Old Sep 20, 2023 | 05:59 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I’m not sure about #1. I’d have to look at my M5OD but it’s 30 miles away.
2) There are plugs in the top cover that leak. I have never done the repair. I’m sure there are write-ups on what to do.
Old Sep 20, 2023 | 07:35 PM
Soup bean's Avatar
Soup bean
I'm not sure about picture one either, but here are two pictures of the rubber plugs that are the likely source of the leak.
The rubber plugs can be removed and RTV'd back in place.
My '88 has no floor cover in it, so all I had to do was slide the shifter boot up, put the transmission in neutral, remove the tunnel cover section of floor, remove the top transmission cover and clean and RTV the plugs.
You'll probably have to remove your shifter, since you probably have carpet in your truck.
When you're reassembling the top cover, get a funnel with a long hose and top off your transmission through the fill plug, or, even easier, fill it before putting the top plate on.
Old Sep 21, 2023 | 08:14 AM
sandymane's Avatar
sandymane
Will add that the transmission should be in neutral when you pull the 10 bolt top cover off.. Check the shift forks for wear. When they get thin they start jumping over the syrnocros and locking up. Great time to put all new Ford type F trans fluid in. Drain fluid and remove fill plug. Put new fluid easily in from the open cover. Replace fill plug when fluid starts coming out of it. Cover has a rubber gasket that you reuse. Tranny is I think a M5OD for search help. Or the R model? About the same thing.
Old Sep 21, 2023 | 04:06 PM
Woodscustom
Thank you guys for your help. I ordered the new plugs. There is a great Youtube video on the process.
Thanks Again!
I would still like to know what that lever with the bolt missing is.
WC
Old Sep 21, 2023 | 04:12 PM
Woodscustom
Rakkasans
WC
Old Sep 21, 2023 | 04:24 PM
sandymane's Avatar
sandymane
All American
63-66
Old Sep 21, 2023 | 09:15 PM
Soup bean's Avatar
Soup bean
All American
63-66
Thanks Again!
WC
I don't know why my phone is quoting sandymane in this response, but I found a YouTube video that explains the lever and bolt at 3:30 and 9:30.
It's a "5th-Reverse Counter Lever Lock Plate" and bolt.
Old Sep 22, 2023 | 07:34 AM
Woodscustom
It's a "5th-Reverse Counter Lever Lock Plate" and bolt.https://youtu.be/OP3_5NUy3JQ?si=WCA_f8lxIngJawDI
Thank you VERY much for digging and finding that. I really appreciate that!
WC
Aerostottle
Dec 9, 2021 05:59 AM
jaroslav
1947 and Older Ford Trucks
Oct 17, 2021 07:54 PM
NOID4RP
May 16, 2021 04:31 PM
rswhitmore
Jun 4, 2017 05:33 PM
