Help Identifying Transmission (2 speed Fordomatic?)
Old May 26, 2017 | 09:58 AM
rswhitmore's Avatar
rswhitmore
Old May 26, 2017 | 10:06 AM
rswhitmore's Avatar
rswhitmore
This transmission came out of a running Ford Falcon (similar to Ranchero), believe it was 1960-1964 Model. It was connected to an in-line 6, I believe a 170 cid. Would like to offer it for sale but not quite sure how to describe it. I believe it may be a 2 speed Fordomatic. Any help?
Old May 26, 2017 | 01:54 PM
85e150's Avatar
85e150
Looks like a C4, which is a later trans. Pictures here:
Ford C4 transmission
Old May 26, 2017 | 07:36 PM
KULTULZ's Avatar
KULTULZ
It is a F/M/2 (One piece bell and main case).
Old May 26, 2017 | 10:46 PM
85e150's Avatar
85e150
Glad you looked further than I did. Is that a true 2 speed, or a 3 speed that starts in 2nd like some of the other Ford-o-matics?
Old May 27, 2017 | 03:56 AM
KULTULZ's Avatar
KULTULZ
It is a true 2/S as it was used on economy applications, full size and intermediates.
The 3/S FM had a cast iron case.
You guys sure are shaking the cob webs loose. Next I will start thinking of women again...
Old May 27, 2017 | 07:03 AM
tjc transport's Avatar
tjc transport
i ain't rite
easy way to tell a 2 speed ford-o-matic from a C-4 or 3 speed select-o-shift/green dot trans:
ford-o-matic has cooling screens in the bellhousing and no trans cooler lines.
the 3 speed trans has no cooling screens and trans fluid lines going to a cooler in the radiator.
Old May 27, 2017 | 10:39 AM
KULTULZ's Avatar
KULTULZ
Exclamation
You just jarred another cobweb, air cooled.
THANX!
Old May 30, 2017 | 07:31 AM
rswhitmore's Avatar
rswhitmore
Thanks for the help guys, I really appreciate your knowledge of Ford parts. Now if I can find a good home for it, or figure out how to mate it to a 226 Flathead.
Old Jun 4, 2017 | 05:33 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C4 and 200 I-6 introduced in 1964, but weren't available in Falcons until 1965.
Only A/T available in 1960/64 Falcon 144/170 I-6's & 1963 1/2 & 1964 260 V8: Anemic Ford-O-Matic two speed. It's get up and go, got up and went.
FJones8668
May 2, 2022 04:05 AM
eberf
Feb 11, 2017 11:36 PM
sandyslt1
1947 and Older Ford Trucks
Aug 14, 2012 11:30 AM
HD74
Mar 28, 2009 11:15 PM
