Help with fan adapter
Old Sep 20, 2023 | 04:23 PM
DStorey1's Avatar
DStorey1
1st Gear
I own a 96 F-150 4.9 (300 cid) six. It was originally equipped with a clutch cooling fan. I want to replace the clutch fan with a Flex-a-lite flex fan. Problem is the original clutch fan has 1-1/4” threads the same as on the water pump pulley. All the fan adapters out there have 30 mm threads. These 30 mm adapters will not work with my water pump pulley threads. Are there any fan adapters that have 1-1/4” threads so I can use a flex fan? I can’t find any anywhere. Does anyone have a solution to this problem?
Old Sep 20, 2023 | 04:47 PM
rla2005's Avatar
rla2005
Keep the factory fan and clutch setup.
GeorgiaSlugger
May 14, 2011 06:59 PM
Shaner911
Mar 11, 2009 05:11 PM
n9lhm
47
Jul 5, 2007 06:59 PM
bluneon
May 17, 2006 09:59 AM
quadzjr
Apr 17, 2006 11:27 PM
