1966 f100 with leaky rear axle
Old 09-19-2023, 10:37 AM
wilkes704's Avatar
wilkes704
wilkes704 is offline
I’ve got brake shoe contamination going on. The truck is a ‘66 F100 with the 240 and three speed. The axle code is 09 which is the 3.70 Ford.
I want to replace all of the bearings and such while I have the axles out. I just want to make sure that I get all of the right parts the first time.
I’m not sure if these images will be of any help. Thank you in advance.
Old 09-19-2023, 04:42 PM
fivestarmmd's Avatar
fivestarmmd
fivestarmmd is online now
I do not have seal number but I use 514003. Bearing with collar. All 28 spline 9 inch I have been in use it.
Old 09-19-2023, 05:50 PM
rsrxc700's Avatar
rsrxc700
rsrxc700 is offline
When I did mine, I just took the numbers off the old parts.
Clean off that ID tag on the axle, may help in ordering parts in case you cant read the numbers off the old bearings and seals.
Knockonwood
08-31-2022 07:33 PM
Woodscustom
31
08-15-2021 02:53 PM
F-1
Ford Truck Parts for Sale
02-08-2018 01:13 PM
2006 F-150 FordSter
05-17-2012 01:07 PM
packrat56
12-22-2007 10:56 PM
Quick Reply: 1966 f100 with leaky rear axle
