differential swap out question
Old Sep 15, 2023 | 07:17 PM
earlcole's Avatar
earlcole
4wd Low
Hello everyone. I cooked the rear differential in my '93 F350, and have decided it "should" be easier to replace the entire axle. It's currently got a D5 axle in it - 10.25 inch, limited slip, with 4:10 gearing. And its a dually. The problem is.... I can't find a D5 within 250 miles! I have, however, found an axle with the code 65. Does anyone know if this will swap out?
Old Sep 16, 2023 | 05:50 AM
tjc transport's Avatar
tjc transport
i ain't rite
the 65 code is actually a slightly stronger weight axle.
your D5 is a 4.10 gear ratio limited slip.
the 65 code is a 4.10 ratio open differential axle
Old Sep 16, 2023 | 05:58 AM
earlcole's Avatar
earlcole
4wd Low
Thanks for your reply, Tom. My biggest concern, since I can't physically see the axle with the 65 code (it's a two hour drive away), is this - will it swap out as is, or am I going to need to change the drive shaft, spring mounts, etc? I know just enough about this to get myself in way over my head, so any advice is much appreciated!
Old Sep 16, 2023 | 06:18 AM
tjc transport
i ain't rite
my big concern would be if it came out of a dually or single rear wheel truck.
they are different width axles. SRW is too narrow for a dually, and dually is too wide for SRW
Old Sep 16, 2023 | 06:20 AM
earlcole's Avatar
earlcole
4wd Low
Both are dually
Old Sep 16, 2023 | 06:29 AM
tjc transport
i ain't rite
ok you should be fine than.
Old Sep 16, 2023 | 06:36 AM
earlcole's Avatar
earlcole
4wd Low
Thanks SO much! I really appreciate you taking the time to help out.
scottw1
Sep 12, 2013 10:00 AM
7.3 Rocket
May 9, 2009 09:44 PM
fordzrule
Jul 5, 2008 10:35 AM
BlueKnight
Mar 4, 2005 11:54 AM
nixon_ca
Feb 13, 2005 12:57 AM
