A/C and defrost
Old Sep 14, 2023 | 08:32 AM
Wilsalmons's Avatar
Wilsalmons
A/C and defrost
I have a 1992 F150 5 speed 5.0, when I turn my defrost on the AC kicks on and off repeatedly. I know it’s supposed to be on to dry out the air or whatever to help with fog and defrosting but shouldn’t it stay on. It never stays kicked on for longer than 30 seconds or so and it’ll kick off for just about as long before kicking back on. It’ll do that until I shut the defrost off. AC works great and is charged with canned air or 152a. Any insight is appreciated.
Old Sep 14, 2023 | 12:28 PM
jas88's Avatar
jas88
Your system is low. I suspect on defrost you have the fan turned all the way down?
Old Sep 14, 2023 | 04:36 PM
Prototypemech's Avatar
Prototypemech
Sounds like your system is working normally. The Ac pump turns on until the high pressure switch is tripped which turns the pump off. Once enough freon bleeds through your fixed orifice to lower the pressure, the high pressure switch makes contact again and your pump turns back on. Usually happens every 30 seconds depending on engine RPM.
Old Sep 14, 2023 | 05:22 PM
jas88's Avatar
jas88
The switch you are talking about works on the low pressure side. It's mounted on the side of the accumulator.
Old Sep 14, 2023 | 11:23 PM
Prototypemech
Ahh. So it does. Any idea what the purpose of the high pressure switch is? Safety shut off switch in case the low pressure fails?
Old Sep 15, 2023 | 04:08 AM
My4Fordtrucks's Avatar
My4Fordtrucks
The opposite of the low pressure switch. If there is too much pressure in the system it will disengage the compressor but that does not apply here. You posted a picture of a ‘94 system which is R-134a and the OP’s truck is a ‘92. That system is R-12 so there is no high pressure switch.
Old Sep 15, 2023 | 07:46 AM
Wilsalmons's Avatar
Wilsalmons
normally in the first or second notch. should I charge it a little bit and see if it fixes it? The pump kicking on and off drives me nuts and I feel it drag the motor way down.
Old Sep 15, 2023 | 12:56 PM
Prototypemech
Thx for the heads up.
Old Sep 15, 2023 | 01:05 PM
My4Fordtrucks
I have no experience with 152a. When doing a conversion from R-12 to R-134a you are supposed to use something like 80% of the R-12 amount. How much are you supposed to use with 152a? Are the pressures good?
Old Sep 15, 2023 | 03:48 PM
jas88's Avatar
jas88
The clutch cycling should be the same on a/c or defrost IF you have the fan setting the same. If you are blowing max fan speed on a/c then that would make it cycle less, and that's about the only thing that can cause this. You should put a set of gauges on it and see what the pressures are.
Old Sep 15, 2023 | 04:55 PM
mlanoux's Avatar
mlanoux
Ah, I wondered what that switch was mounted on the back of the compressor was for...I guess you can think of that as an OVERpressure cutoff switch...learn something new every day....and I concur, it's probably low on refrigerant and the low pressure switch is at play here.
Old Sep 16, 2023 | 11:28 AM
Wilsalmons's Avatar
Wilsalmons
everything I’ve read says 152a acts pretty much the same as r12 except you can’t use mineral oil. So I went off that and charged it with around 25oz. It kicks off occasionally with AC but it’s either a lot less often or a lot less noticeable.
Old Sep 16, 2023 | 11:30 AM
Wilsalmons's Avatar
Wilsalmons
I have a set of gauges and I’ll plug it all in next chance I get. But I remember from the past the low side was always way to high and the high side way to low. Could the wrong orifice tube cause this. It has the blue one right now but I have a new red one I’ve thought about replacing it with.
Old Sep 16, 2023 | 01:06 PM
jas88's Avatar
jas88
Red is correct for R-134a. Blue is for R-12.
Old Sep 16, 2023 | 05:44 PM
My4Fordtrucks
He has filled the system with 152a so….use the blue one?
