First service
Old Sep 11, 2023 | 01:48 PM
tsmithco's Avatar
tsmithco
First service
It's time for the first official oil change of my '22 6.7 DRW. it's at 5% and I just hit 6,000 miles on the truck.
I don't see anything else in the service area of the manual to do at this time. Is that right?
What would you do at 6k miles on a now 10 month old truck? just change the oil? My previous truck was purchased used, so I've never had the "first" service for it.
Old Sep 11, 2023 | 03:22 PM
zmetalmilitia's Avatar
zmetalmilitia
I would change the oil and check all the other fluid levels, well the easy to check ones like power steering, coolant, etc. The ones that are a bit harder to check are the transfer case, diff, and tranny. The fluid levels are probably okay but there was a thread where someone had low transfer case level. Hopefully the dealer checked all of that for you. That's all I can think of doing with only 6k on it.
Old Sep 11, 2023 | 04:11 PM
Painted Horse's Avatar
Painted Horse
I usually do my first oil change at 5,000 miles. After the first service, I start to follow the Oil Life Monitor. Something more in the 7,500 range for the second and then 8,000 to 10,000 for the all oil changes after that.
Oil and Oil filter for the 1st and 2nd change. Then I add air and fuel filters ever other oil change after that.
And I usually get the first oil change done by the dealer and I do most of the following oil changes if the weather permits. If it's nasty out, I let the dealer do mine. But then I put 3,000 miles a month on my trucks. So it's four oil changes a year for me.
Old Sep 11, 2023 | 04:41 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Get your grease gun out and tackle those front axle u-joints, would be the only other service you might want for a year old truck.
And, of course, service intervals are not only mileage based, and I don't recall if there is any other recommended service at one year, maybe fuel filters.
Old Sep 11, 2023 | 04:47 PM
Vipersgts1's Avatar
Vipersgts1
I'm far from an authority on this but when I went in for the 1st service on my 23' 7.3 I reviewed the owner manual service interval details and had them perform the "10k maintenance" @6000mi. I asked that they grease front end (arent alot of great points sealed nowadays?) and check front steering and suspension components for play and premature wear indicators. I might do the next oil change myself. Alot more expensive than my 6.2 f250. That was usually $38-44. 7.3 was closer to $70-80 i believe. I also like noting down what was done on ford pass app so I can refrence that for future services.
Old Sep 11, 2023 | 05:27 PM
Flitastic's Avatar
Flitastic
No front end grease on the 23's! Yea!
Old Sep 11, 2023 | 07:35 PM
Vincent_Diesel's Avatar
Vincent_Diesel
Is this a question?
Can someone verify on 2023s there are NO grease fittings at all to maintain?
Old Sep 11, 2023 | 07:54 PM
4wd6.7L's Avatar
4wd6.7L
Originally Posted by Vincent_Diesel
Is this a question?
There was another recent thread where it was determined by several '23 owners that the SRW trucks no longer have any grease fittings. The 450 still has them.
Old Sep 11, 2023 | 11:05 PM
Flitastic's Avatar
Flitastic
Is this a question?
not a question sorry . I was just saying I started the thread last week . Even on my DRW 2023 there are no front zerks to grease like my 19 had
Old Sep 18, 2023 | 06:39 PM
Squanto's Avatar
Squanto
Where are they on a 22? I thought on the 4wd u joints but didn't see any there.
Old Sep 18, 2023 | 06:45 PM
Squanto's Avatar
Squanto
Dup delete
mojavearcher
Apr 2, 2023 10:36 PM
61 uni
20
Dec 31, 2008 04:57 PM
slash36g
2004 - 2008 F150
Nov 21, 2008 08:18 PM
gafft1
1997 - 2003 F150
16
Oct 9, 2006 12:04 AM
jschira
Oil & Lubrication
Apr 27, 2004 05:44 PM
