How much oil between changes
Old Dec 30, 2008 | 07:57 AM
61 uni's Avatar
61 uni
Bought my truck yesterday and the oil level was below add and looked like it hadn't been changed in a while. Had they change it before I bought the truck. Do you guys have to add between changes?
Old Dec 30, 2008 | 08:06 AM
BENG0924's Avatar
BENG0924
I dont but I have heard ford considers anything less than a qt per 1000 miles normal
Old Dec 30, 2008 | 08:12 AM
03_PSD's Avatar
03_PSD
I usually have to add a quart or two about 4-5k miles into an oil change.
I would go ahead and change the oil in your truck, just to be on the safe side.
Old Dec 30, 2008 | 08:14 AM
61 uni's Avatar
61 uni
I had them to change the oil and tranny fluid.
Old Dec 30, 2008 | 08:42 AM
novice psd's Avatar
novice psd
zero, I change every 5000 miles.
Old Dec 30, 2008 | 08:55 AM
white Buffalo's Avatar
white Buffalo
When I pull the 5th wheel alot during the summer I will have to add a quart.
How many miles are on your truck? and what type oil did they put in it for you?
Old Dec 30, 2008 | 09:21 AM
Ponyboychris's Avatar
Ponyboychris
Originally Posted by white Buffalo
...what type oil did they put in it for you?
^^^^What he said, which oil are they putting in there. Make sure it's diesel rated.
Old Dec 30, 2008 | 10:04 AM
F250_'s Avatar
F250_
I'm running 13K-15K between changes, and generally use about 2-2.5 quarts in that time frame between changes.
Old Dec 30, 2008 | 11:31 AM
HKusp's Avatar
HKusp
2 quarts per 7-8K and I have a small leak that is getting bigger. Just got my new blackstone report back and it was good. Silicon is going down steadily since removing the stock airbox.
Old Dec 30, 2008 | 11:42 AM
61 uni's Avatar
61 uni
81K. They put motercraft 15w40. I allways run rotella, but may switch to delo.
Old Dec 30, 2008 | 12:55 PM
liftedgrocerygetter's Avatar
liftedgrocerygetter
Are you sure they changed it like you told them to......
I am going 5k between changes and don't have to add any in my truck.
Old Dec 30, 2008 | 01:41 PM
61 uni's Avatar
61 uni
I didn't watch them, but it is full and clean. Sticker says 15-40.
Old Dec 30, 2008 | 01:43 PM
liftedgrocerygetter
Okay, I misunderstood your post then, sorry.
Old Dec 30, 2008 | 01:59 PM
61 uni's Avatar
61 uni
No problem, it was a typo for my part. I don't know how long the old oil was in there, but it was a while. It sat on the lot a month. Don't know why though. If i wasn't upside down on my trade, I would of got it for 13,900.
Old Dec 30, 2008 | 02:17 PM
brian42's Avatar
brian42
Veteran: Navy
I add 1-2 qts every 5K, but I've got some weepage (looks like the turbo pedestal) and 172K on the odometer.
