Steering Box Tightening Question
Two questions.
Background - My steering was a little loose so I looked at some videos and found the adjustment screw. The videos don't really show what to do, they just tell you. So I loosened the nut (16mm) and then could not figure out how to move the center screw. SO I just tighened it up again. But just that did tighten it up a little, I guess because the center screw moves. My two questions:
1 - how do I adjust the center screw itself?
2 - how tight is too tight? Right now, it feels pretty good but if I turn the steering wheel anywhere from 10-2 oclock, it will stay there. In theory, this is too tight, right? On the other hand it feels like reman steering boxes I've installed in other cars. Is it possible that I'm within the margin of error or should I back it out a little bit?
Thanks!
There's no flathead mark. Actually at first it looked like a hex fitting but then turned out to be just a circle.
I've never done it. If your steering won't return to center, it's too tight. Over the long run, having it too tight could damage your steering box.
Have you checked the shim in this video? I found this while researching ways to tighten my steering. I haven't tried it yet but it's where I plan to start. https://youtube.com/watch?v=1M2gAy5HSdM&si=M6URaJ4zeE3YOib3
IIRC I adjusted mine 10or so years ago and its again at that point where its sloppy. I rebuilt the front end by replacing all the ball joints and tie rods and its still not where I want it so I gave mine a 1/3 of turn and dont like the feel. In the last month I replaced the rear springs and shackles, the fronts are on there way and I'm going to do the pivot bushings. The plan is to do a string alignment and then get a new box and have it machine aligned. Just have to spread out the parts a little as its gotten expensive over the summer.
1 - HOW do I adjust this? Right now, the inner screw turns more or less with the nut. I've remove the nut enturely, greased it, etc. I do not see a way to turn the inner screw by itself, or to hold it in place while I tighten the nut. Someone said a slotted screwdriver. What do you use it on? I don't find any slots.
2 - Is it too tight as I described? The wheel feels pretty good, but it does not snap back from 11 or 1. Beyond that, it does snap back to about 11 or 1. It feels like another car I have with a new steering box, but people say if it doesn't snap back all the time it's too tight. I'd like other opinions. I just never paid this much attention before I don't think.
Roger Wilco on needing a new box and planning that purchase/installation starting now. But if you could tell me how to perform the adjustment, I would appreciate it. What tool do you use and where?
I mark the gear housing where the slot is lined up so I have a starting point for reference. Then I loosen the nut while holding the adjustment screw with a screwdriver. I tighten the screw a couple degrees, tighten the locknut and recheck for “free play” in the gear. If needed -repeat the process. DO NOT take all the play out of the gear or you will not only cause the wheel not to return to center but also damage the steering gear.
Here is how it says to do it in the service manual
I hope you only removed the nut and not the screw. If so, you now have no idea where it was previously.
From what you described, it does seem like it is now too tight.
Not to be rude but it sounds like you are in over your head. Drive it like it is until you can replace the gear.
... it takes skill to drive mine. Anyway it also feels loose and I think that could be your problem. As for adjustment of the steering box itself I think there isn't much adjustment to it like My4Fordtrucks is saying. I tried that on my 76 F150 and it I couldn't ever get it to tighten up. It was either too tight or loose as hell. I've heard everyone say it's just a Ford thing. If it's that bothersome it's probably best just to replace the steering box.
Not sure what answer you are looking for as I have overhauled a hundred or more steering boxes myself as well
The sector shaft adjusting screw turns damn easy without the nut on there, but with the nut it's tough
If you remove the nut it needs to be replaced (a new one comes in a gear seal kit)
Not a magic bullet & not rocket science.
My process:
Flat head screwdriver & box wrench. Place screwdriver in slot. Hold fast. Break nut & swing wrench counterclockwise 90*
If screw driver moved, turn clockwise to original position that you thoughtfully pre-marked.
Turn screwdriver 45*, or quarter turn clockwise. Tighten nut without moving screwdriver. Done. NO MORE
