Battery Replacement
Old Sep 5, 2023 | 10:16 AM
harmanrk's Avatar
harmanrk
Battery Replacement
Batteries in my 2017 (built 9/22/2017) finally went out this weekend.
Last week I had an issue when the truck was started, and it popped up several odd errors, Service Advanctrac, Stability Control Not Available, and something about the rear parking sensors (Do not remember the exact msg). I was able to shut off the truck and restart with no errors.
This weekend, I whet to start the truck and had nothing. No dome light, radio, or anything. I was able to track down a pair of Motorcraft Group 65, 850 Amp (Up from the factory 750) for a bit over 2 bills each (ouch). Brought them home and installed them. Had lights and radio as soon as they were installed, but no crank, and no gear indicator (PRNDM). Tried multiple BCM resets without luck. Finally made an appointment with the local dealer, and called AAA to have it towed. When the tow truck arrived, they asked me to put in in neutral to load it. When I got in, I noticed I has the gear indicator, so I thought I would try it. I did and it started. I am not sure if there is an anti-theft system that requires a long reset after the battery is replaced or what, but it was just strange.
I thought I would post this in case it is helpful to anyone else. Here in a few weeks I will be replacing the factory tires. This will be another large OUCH moment.
Old Sep 5, 2023 | 10:44 AM
99powerstrokedF250's Avatar
99powerstrokedF250
I believe that some people have had that issue, where after swapping the batteries the truck needs some time (sometimes up to 8 hours?) to properly reset itself. It can't hurt to have the dealer check it if you don't mind paying for the diagnostic fee.
Old Sep 5, 2023 | 10:55 AM
harmanrk's Avatar
harmanrk
Thankfully it was only a 45 minute to an hour wait for the 'reset'. Was the first time I have seen a need wait after a replacement. Too many computers on these things.
Old Sep 5, 2023 | 11:19 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Did you pull both old batteries at the same time to put the new ones in?
Old Sep 5, 2023 | 11:28 AM
6.2caribou's Avatar
6.2caribou
I think that I can see where you're going here. If leaving one battery connected is the "answer", how then would you change out a single battery on a gasser and not have the op's issue?
Changing batteries on my 6.7 Cummins was always a potential sparkfest if I didn't at least disconnect both positive leads when I started.
harmanrk's Avatar
harmanrk
Yes, both were around 11.5volts, and were replaced together.
Old Sep 5, 2023 | 11:57 AM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Reason I asked was that if you only take one out at a time, and put the new one in, then the truck never loses voltage, so its system stays live during the replacement, keeps the issue you had from happening.
Also, just so you know in the future, battery voltage doesn't tell the story on battery health, only charge level.
Old Sep 5, 2023 | 06:52 PM
hondomurph's Avatar
hondomurph
I replaced both oem batteries with AGM batteries on my 2019 6.7 at the same time . After snugging down the post clamps I installed the battery hold downs . Jumped in and started it up . There was never any delay or any problems with everything loading properly . Let it run for a minute or so and drove for about 15 minutes . I'm not sure why his truck had a long delay .
Old Sep 5, 2023 | 07:34 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
There is a reset for replacing batteries, at least on 2020+, they had to do it on mine when they replaced the batteries, hooked up the scan tool to do the reset.
My thought is that if the voltage is not completely disconnected by removing both batteries at the same time, you could get around that.
Old Sep 5, 2023 | 11:52 PM
Garbageman 134's Avatar
Garbageman 134
There us a handy little tool that plugs into the "cigarette" aka power port that delivers 12vdc so the vehicle doesn't lose power. Not sure if that will work on a newer vehicle that has a BCM that controls everything
Easy enough to clamp a couple of wires onto the battery cables and connect the other ends of the wires to a spare battery
Old Sep 6, 2023 | 04:17 AM
harmanrk's Avatar
harmanrk
It is possible that mine sat with dead batteries for up to a week. It may be that the computers have capacitors that are able to maintain them through a short outage for a swap.
Old Sep 6, 2023 | 02:35 PM
pjsinAK's Avatar
pjsinAK
Just completed battery replacement and was similarly concerned about a "spark-fest." Those cables are thick and set in shape so they resist staying tucked safely out of the way. I used a short bungee cord attached to the hood catch to hold the hot/positive cables out of the way while i disconnected, removed and replaced/reconnected each battery one at a time.
triton54
2015 - 2020 F150
May 17, 2023 02:54 PM
Lebowskii
2015 - 2020 F150
Apr 9, 2023 10:50 AM
cstoc235
2009 - 2014 F150
Jan 31, 2016 01:23 PM
howard gustave
Feb 10, 2005 07:59 PM
gofastbig3
1997 - 2003 F150
Nov 9, 2000 12:27 PM
