2000 Expy overheats now...
Old Sep 8, 2023 | 12:22 PM
scattermaster's Avatar
scattermaster
Originally Posted by alloro
Water boils at 212F which is why you need some coolant in there. Without coolant the water will boil and turn to steam.
Everything you just described in your last message points to a clogged radiator. Perhaps there is an issue with it, have you flushed it out?
the radiator is brand new. (about a couple months old )
That doesn't 100% mean it's not clogged up but I haven't seen any other signs of foreign material suspended in the coolant. The old thermostat was clean. Inside of the old hoses are clean too.
I was running a new but very cheap temp sensor from Amazon that might be suspect. Yesterday morning it was reading 130 deg and I hadn't even started the engine yet! (truck was parked in the shade)
I'm going to change that sensor out for the $100 MotorCraft one that I picked up this morning. Hopefully it reads cooler. (and hoping the engine is running cooler than the computer thinks it is...)
thx,
Jim
Old Sep 8, 2023 | 06:38 PM
scattermaster
I fixed it!
It was the cylinder head temp sensor the whole time.
I'm not sure how I came up with the part number I ordered the 1st time but it was wrong.
I bought another one today at a local parts store. I compared the 2 sensors with an OHM meter and they were way different. The newest one had a lot more resistance.
The lower resistance made the computer "think" it was a lot hotter than it was. It also caused the oil light to come on and threw it into limp mode several times yesterday.
I thought it was odd that the oil light was on but the oil pressure "gauge" in the dash remained at normal.
I put the new sensor in the truck and it runs great. I actually can't get the engine to operating temp! (no thermostat installed)
Tomorrow I'll flush out and refill the coolant system, install the thermostat, and I'm good to go.
thx,
Jim
Old Sep 8, 2023 | 06:51 PM
Hit Man X's Avatar
Hit Man X
Kickass. Glad resolved.
PhilMcC
West Virginia Chapter
22
May 3, 2022 08:04 AM
Oliver Roe
Aug 29, 2021 06:51 PM
brewerkz
Apr 17, 2017 09:03 PM
Adamgators
Aug 22, 2015 11:49 PM
Philip1991Explorer
Aug 1, 2003 08:30 PM
