Front wheel bearings with plastic cage
Hi Folks,
I apologize in advance if this has been discussed a hundred times previously, but I did a couple searches and couldn't find anything. My 1994 F150 (2wd) is making what I assumed was a wheel bearing noise on the highway. Not serious, but I didn't know what else to attribute it to.
So I checked the front end, and wheel bearings are loose on both left and right. I figured OK, I'll tighten them up a bit for now and order in a new set of bearings. I tried to tighten the bearing nuts, and they're already bottomed out. I removed the outer bearing, and it has a flimsy plastic cage...I've never seen such a thing in my life. So I guess they're either the wrong bearings, or the right bearings and just extremely worn out to the point they cannot be snugged up.
Has anybody seen these plastic bearings before? They're stamped Timken, but I found them on RockAuto under the brand name BCA.
The Timken ad I found says O.E. Polymer Cage. Did these trucks come with these bearings originally? I think I'd prefer a regular set of all steel Timkens in there regardless.
The following users liked this post:
N147JK
10-04-2021 05:26 PM
fatheroftwo
02-23-2016 09:07 PM
F150Lariat79
02-05-2003 08:10 PM
