Raising compression
Old Sep 4, 2023 | 02:30 PM
Garbageman 134's Avatar
Garbageman 134
Raising compression
I have random thoughts about random things all the time and this popped into my head recently. The factory compression ratio is 10.5:1. Is it possible to have the heads milled down in order to bump up compression for a little more horsepower?
Would be nice to install the ProCharger kit but then you have to run 93 octane all the time
Old Sep 4, 2023 | 02:37 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Well, you could, but milling the heads creates all sorts of other things that then have to be compensated for, so to do that right would cost a fortune, not be worth the small gain. Plus raising the compression ratio would cause the same fuel requirement as the supercharger.
You could get as much added power from a dyno tune as from the increased compression.
Old Sep 4, 2023 | 06:33 PM
OBS460's Avatar
OBS460
You want to lower compression if you don't want to run premium.
Old Sep 4, 2023 | 06:36 PM
Garbageman 134
At what point does one need to switch to 89 or 93?
Old Sep 4, 2023 | 06:50 PM
OverheadCram's Avatar
OverheadCram
When there is predetonation present. With that said its not as cut and dry as that when engineering a combustion chamber along with the rest of the engine. There is no set compression ratio that is the benchmark switchover point for a higher octane fuel.
Old Sep 4, 2023 | 08:10 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
When you can't adjust the tune enough to keep it from preignition or loss of power.
There is no specific magical number.
SFaulken
16
May 5, 2021 04:21 PM
harvy
Jan 30, 2011 10:16 PM
jon87transam
Mar 8, 2008 10:16 PM
Johnboy_BoomerSooner
General Automotive Discussion
Apr 21, 2004 08:45 PM
erikl85
Nov 25, 2002 10:45 PM
