2015 + Expedition & Navigator 2015 + Ford Expedition and Lincoln Navigator
Front rotor removal
Old Sep 4, 2023 | 09:39 AM
SlikWillie's Avatar
SlikWillie
Front rotor removal
This trick might be known or covered somewhere in these threads, but I could not find anything. So I'm posting a little trick I used to remove the front brake rotors without beating on or banging on anything.
After removing the caliper and caliper bracket, I used a 9/16 bolt, a couple washers and a nut. Stick the bolt through the caliper bracket hole and then the washers and nut. Now, just hold the nut with a wrench and tighten the bolt with another wrench or socket/ratchet and it will push the rotor off with ease. Hope this helps somebody in the future.
SlikWillie
2015 - 2020 F150
Sep 20, 2023 07:54 AM
sanman1969
132
Apr 25, 2019 09:40 AM
Roostee Lips
1997 - 2003 F150
Jun 15, 2012 05:31 AM
danlee
Apr 5, 2008 12:03 PM
mmmchickenboy
37
Feb 21, 2007 07:50 AM
