universal joints
Old Sep 2, 2023 | 12:52 PM
jodiedog's Avatar
jodiedog
Trailering
universal joints
I have a 1989 f250,auto trans,5.8l , standard cab , 8 foot bed, have a noisey front universal, I want to change them both,front and rear. my question is are they both the same? I had another 89 f250 that I worked on years ago,but I don't remember.Thanks for listening...Jodie ps.. I do a lot with Rock Auto but there seams to be a lot of options
Old Sep 2, 2023 | 01:06 PM
Conanski's Avatar
Conanski
There are 5 universal joints in the front driveline... 3 in the axle and 2 on the driveshaft.
Old Sep 2, 2023 | 01:41 PM
jodiedog's Avatar
jodiedog
Trailering
thanks for the reply.but it is a rear wheel drive only.have 2 universals on the drive shaft,are they both the same.?..
Old Sep 3, 2023 | 06:44 AM
manicmechanic007's Avatar
manicmechanic007
If your rear axle flange has U bolt straps with 1/2 inch nuts the u joints are different front and rear
If the rear axle flange has 12mm bolts the U joints will be the same
Your 89 should have U bolts and slightly bigger caps under those U bolts IMO. The rest of the caps are the same size, and the star is the same size
Old Sep 3, 2023 | 09:37 AM
jodiedog's Avatar
jodiedog
Trailering
Thanks,I thought that might be the case,but I wasn't sure..
FSeriesAwesome
Jul 21, 2020 08:54 PM
rkeith213
Feb 23, 2015 05:29 PM
harker70
Oct 28, 2012 12:56 AM
bubbasinafordf150
17
Jul 26, 2010 05:53 PM
agertool
Jun 7, 2010 07:09 AM
