Converting to amber blinkers in the rear
Well I'll be ... you're exactly right . Looks like our tests after adding them was with no other lights (or brake lights) on. And since I haven't driven behind my son's truck since then, I had no idea. Also looks like I'm gonna work towards adding the two wires into the front turn signal circuits back there when it gets a bit cooler out. Thanks!
Can't seem to get away from running wire or wires though.
Instead of a diode, why not just cut the brake wire from the turnsignal switch? That would turn the two original wires running to the rear from brake/turn to just turn left and turn right. You would then have to cut the wires at the rear and move them to the new amber turn bulbs. Then take the brake wire that was cut under the dash and extend it all the way to the rear and tie it to both old red brake/turn bulbs left and right, and they would both just become brake only. You would have to run just one wire to the rear with this method, but maybe just a little bit more work at the rear taillight area. I believe the hazards would still work properly, blinking the amber turns only.
You really have to divorce the brake lights completely from the turnsignal switch. If you don't, when you move the lever one of the brake lights will go out since the turnsignal switch will disconnect it.
The following users liked this post:
hbhollomon
11-09-2021 04:52 PM
JM5034
03-19-2007 07:13 PM
