Help diagnosing a misfire
Old Sep 1, 2023 | 07:01 PM
redbrick5.8's Avatar
redbrick5.8
3rd Gear
Hi everyone, just bought a 1990 f250 with a 5.8. Ive had an issue with the battery draining over night. Ive been just disconnecting the negative bat cable for the past week. Previously I would hear a clicking coming from the pcm relay everytime i would touch the cable to the battery even with key off. I did something and now it doesnt click and now it doesnt drain. However recently Ive noticed something that sounds like a misfire. I can hear it a lot on the passenger side due to an exhaust leak there. I went to the tailpipe and it def sounded like one as well. I pulled two plugs on teh passenger side and i was told that im running lean right now. Does anyone think theres a correlation between the battery drain and the misfire? Also i dont hear it when i rev it in idle, its only under load where i really notice the loss and power and sound of the misfire. Also whenever I press the brake pedal down it sounds like air is being released somewhere, maybe a possible vac leak. Would this contribute to the misfire if i did have a vac leak? Anything would be appreciated, thanks.
Old Sep 1, 2023 | 07:14 PM
Anonymous12's Avatar
Anonymous12
Vacuum leaks will cause a misfire, probably why your lean to. I had a connector break on the vacuum line and it had a bad misfire at idle, and especially accelerating. So I would look for that vacuum leak.
I would check the plastic vacuum lines on the passenger side, those are very very brittle if they never have been changed.
Oversized Chuck
1997 - 2003 F150
May 7, 2017 09:17 PM
hojolabo
1997 - 2003 F150
Nov 1, 2015 03:38 PM
John Irwin
Jul 3, 2008 08:55 AM
shooked
Feb 12, 2006 01:34 PM
maa139
General Automotive Discussion
Aug 27, 2004 05:20 PM
