General Automotive Discussion
Garden tractor trouble...
Old Aug 22, 2004 | 08:38 PM
maa139's Avatar
maa139
I have a craftsman 14.5 hp garden tractor with a Briggs and Stratton engine. The battery is brand new, bought a week ago. I cut the grass last week after putting in the new battery. I went to mow today, and the battery was dead. It only showed 4.5 volts across the terminals. I need to get the grass cut, so I jumped it from my Explorer. When I finished mowing and turned the mower off, there were 11.7 volts across the battery. Anyone ever have this problem? I'm a little confused. If the alternator was bad, would the battery have taken ANY charge while I was mowing? I'm thinking that there must be a short somewhere that is drawing current from the battery when the motor isn't running and the key is off. Does it sound like I'm on the right road or am I completely off track?
Thanks in advance.
Matt
Old Aug 22, 2004 | 09:01 PM
theonlybull's Avatar
theonlybull
sounds like your on the right track to me. the alt may have a leak in it, which causes the drain. but also alows it to charge. remove the - batt cable, and see if you get a spark when your reattach it, if so, there's something drawing current, unhook onething at a time till you find it
Old Aug 22, 2004 | 09:18 PM
brownie65's Avatar
brownie65
Make you a light & unhook your negative battery cable. Hook the light up between the neg cable & the neg post on the battery. If it lights you have a short somewhere. As last post said unhook things until light goes out . Same as checking for a spark when you hook the cable up , this is just easier.
Old Aug 27, 2004 | 05:20 PM
maa139's Avatar
maa139
The problem appears to be the connection on the solenoid. With a wire brush, I cleaned those connections and every other electrical connection that I could find. I charged the battery and it appears to be holding it's charge. Thanks for the help guys!
Matt
