Ford 400 HEI Wiring
Ford 400 HEI Wiring
Hello, was searching through these forums and never found exactly what I was searching for, so I’m going ask.
I’m installing a Ford HEI distributor and am trying to figure out wiring. I’ve got a 14 gauge wire (to handle the 12V), from the Start tab on ignition switch to the Start side of the solenoid, and then another 14G wire from the I side of starter solenoid to the BATT tab on distributor. That’s it. It turns over, but doesn’t start. Please help with any advice. I’m stumped.
Well, I would look at the HEI itself (the coil and the rotor) they are common failure points as is the module
I have some diagnosis materials for their system as Ford taught the competition at times in their drivability classes
I was able to get a few books out of the deal. They always had a table of free books at screwell
If you have the BAT wire hooked to key on power or any power for that matter it should be sparking
All the HEI needs is a single 12V+ to run. It should be a keyed power source. IIRC, mine is more like a 10ga wire, so you might not be getting sufficient current through the 14ga. I'd pull a plug, set it on the exhaust manifold, & watch the spark while someone else cranks the motor a couple turns. Should give you an indication of whether you're getting a good spark. Also make sure your timing is correct.
The following users liked this post:
on
wilkes704
18
11-01-2022 07:19 PM
maclif
07-06-2016 01:27 PM
hulleywoodworking
04-20-2016 04:40 PM
