Sponsored by: Real Truck
Another “no horn” post
Old Aug 31, 2023 | 05:25 PM
jkg123's Avatar
jkg123
4th Gear
2003 F-250 no horn.
fuse 37 is good.
just replaced clockspring.
horn pad has been replaced in last 3-5 years
horns were replace within last 5 years.
truck sits for extended periods of time.
when pressing horn pad/button there is no sound no click of relay nothing at all.
Old Aug 31, 2023 | 06:10 PM
projectSHO89's Avatar
projectSHO89
If the horn relay in the under-dash fusebox isn't "clicking" when the horn pad, switch, clock spring, etc has a problem somewhere along the line.
If you have remote keyless entry, does the horn work in PANIC mode or when locking/unlocking from the fob?
Old Aug 31, 2023 | 07:05 PM
jkg123's Avatar
jkg123
4th Gear
I haven’t tried the panic button on remote or double lock. I will try that tomorrow..
Old Aug 31, 2023 | 10:57 PM
PJWhelan's Avatar
PJWhelan
Check wiring at the horn too. Corrosion is super common....
Old Sep 1, 2023 | 06:41 AM
projectSHO89
Wiring problems at the horn won't cause the horn relay to not activate unless F37 was taken out. He indicated it is good plus there was very recent work done to the clockspring area.
Old Sep 4, 2023 | 04:29 PM
jkg123's Avatar
jkg123
4th Gear
No horn From “double tap” on remote lock. No horn when pressing “panic” button on remote.
Old Sep 4, 2023 | 06:06 PM
projectSHO89
And the relay did what (if anything)?
Old Sep 4, 2023 | 06:14 PM
jkg123's Avatar
jkg123
4th Gear
[QUOTE=projectSHO89;20965336]And the relay did what (if anything)?[/QUOTE
I can not hear the relay over the sounds of the power locks on “double tap”.
When I press the panic button all I can hear is the flasher relay working the flashers and the interior chime going off/on off/on….
old-dad
1997 - 2003 F150
Mar 12, 2018 11:34 AM
Snapper3
Nov 9, 2012 03:42 PM
johnboggs21
Sep 8, 2009 08:57 PM
Hi Ho
Electrical Systems/Wiring
Apr 21, 2003 12:17 AM
cobraguy
Apr 21, 2002 12:57 PM
