P0301 code issue and check engine light flashing
Old Aug 31, 2023 | 02:06 PM
BradSutphin's Avatar
BradSutphin
2nd Gear
2017 F-250 Super Duty 6.2
I keep getting a P0301 or 0300 code from time to time. What could be causing this?
Also I tow a 33' bumper pull camper, when I was towing this past vacation I noticed the check engine light will flash when it down shifts from 4th to 3rd trying to pass, but when I tow with the "haul mode" on it doesn't not come on at all. I was towing up a steep upgrade with it in "haul mode" and it never flashed. Could someone point me in the direction of what my problems could be?
Old Aug 31, 2023 | 02:10 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
You guys have to remember to give details on your truck when asking tech questions.
Old Aug 31, 2023 | 02:11 PM
BradSutphin
2nd Gear
Sorry new to the board, it is a 2017 F-250 Super Duty XLT 6.2
Old Aug 31, 2023 | 02:13 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Apparently you have a gas engine truck, going by the codes.
Could be bad plug wires, bad plugs, bad coil packs, harness issue.
P0301 indicated cylinder 1, start there.
Old Aug 31, 2023 | 03:13 PM
morehouse7's Avatar
morehouse7
Depending on your mileage but probably a coil pack on cylinder 1 (hence P0301) and the P0300 is for random misfires. You can try servicing it with a ~$10 rebuild kit. New ones are ~$150 each from Motorcraft or Napa
See my post about the subject
https://www.ford-trucks.com/forums/1...xperiment.html
ItsJeffie
Oct 28, 2022 01:38 PM
kf1128
Oct 7, 2014 03:28 PM
ltharper
Oct 24, 2013 07:30 AM
Monstertruckchick
Sep 23, 2011 07:41 PM
JoggingGuy
1983 - 2012 Ranger & B-Series
Dec 10, 2003 05:02 PM
