Tow Light flashing
Old Sep 23, 2011 | 04:09 PM
Monstertruckchick's Avatar
Monstertruckchick
Tow Light flashing
I was driving to work when suddenly the tow light started flashing. I wasn't towing anything - just comes on and off... suggestions?
Old Sep 23, 2011 | 04:11 PM
2006powerstroke90's Avatar
2006powerstroke90
How is the transmission acting? Fluid level and smell? Any leaks?
When my truck did this..I ended up putting a new transmission in it..
Old Sep 23, 2011 | 04:15 PM
Monstertruckchick
no power...
It just ran like it was really colld... didn't want to go over 40 -
Piolet's Avatar
Piolet
If that light is flashing it means there is a code being stored by the computer. A regular reader might not work. I believe you'll need one of the really capable ones ... like AE.
Old Sep 23, 2011 | 04:16 PM
Monstertruckchick
Where should I take it? I have a mechanic that can fix anything, just doesn't have all the diagnostic equipment....
Old Sep 23, 2011 | 04:20 PM
2006powerstroke90
I had a transmission shop scan mine, got codes my reader didn't catch. They were all transfer case codes though.
Ford might be able to do it quick, or a local transmission shop will probably do it for free or maybe a coffee
Old Sep 23, 2011 | 04:31 PM
ljutic ss's Avatar
ljutic ss
Is the trans temp gauge in the dash reading very hot or cold?
Old Sep 23, 2011 | 04:45 PM
Monstertruckchick
Temp is normal.
Old Sep 23, 2011 | 05:11 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Much more info in the Tech folder but this is about temps:
04-13-2009 | 11:53 PM
bismic
Temperatures and OBD-II info:
An aftermarket temperature gauge is highly recommended.
The "Factory" transmission temp gauge, it is a glorified "idiot" light as its response is severely dampened. The panel gage will show the temp as fully warmed up at 50 *F. Between 100-220F the needle will remain in the same position on the gauge. At 230F it will move up slightly to the middle of the normal range. At 250F it will move to Yellow. The gage moves to red at 280. This is supported on page 36 of the OBDII Theory and Operations manual. The tow/haul light will flash at 275.
I am probably being conservative, but transmission temps much over 230 are probably a little too warm for continuous service in my opinion. Similarly, I would recommend to never exceed 250 for more than a short duration - say 30 minutes. Note - this is because a measured temp of 250 actually means some areas and parts may be as high as 300 - synthetic tranny fluid should be good to 300 *F or so.
Quote
Old Sep 23, 2011 | 05:20 PM
Piolet's Avatar
Piolet
https://www.ford-trucks.com/forums/8...ml#post7670499
Quote:
"There are at least 50 different reasons why the tow/haul would flash. The ONLY way to know why is to have the codes read. You need to have a very specific tool to be able to read Ford transmission codes. Anywhere that will read codes free won't have this tool."
Posted by
Mark Kovalsky
Former Ford automatic transmission engineer, 1988-2007.
I guess that answers my question too
Old Sep 23, 2011 | 05:26 PM
tex25025's Avatar
tex25025
That is probably the last thing that I would go by. When my tranny finally went after the build that I did to my truck (I was expecting it to go out), my factory gauge showed nothing out of the ordinary and my direct clutch was burned up pretty bad (only true weak link in these trannies in my mind).
Old Sep 23, 2011 | 05:57 PM
ljutic ss's Avatar
ljutic ss
If you ever had a TFT sensor go south you would have understood my question. When they fail they can effect the shift patterns like hanging up in third. They will also spike the temp needle along with the check gauge's coming on, but not all these symptoms will occur.
Old Sep 23, 2011 | 07:41 PM
tex25025's Avatar
tex25025
Nope, still on the original sensors for my truck.
doug6776
2009 - 2014 F150
Jul 5, 2016 02:46 PM
ltharper
Oct 24, 2013 07:30 AM
MR C 57
Feb 6, 2011 09:36 AM
sctrooperlx
Jun 11, 2009 07:45 AM
balljoint
Feb 23, 2008 10:00 AM
