starter issues
Old Aug 29, 2023 | 04:13 PM
MartyJB's Avatar
MartyJB
4wd High
starter issues
Hi, I just rebuilt my 390 from my f350. The question I have is this, When I turn my starter key to the run position the engine starts and runs without having to go all the way to the right or the start position. I've used the hot wire that used to go to the coil to wire my HEI distributor. The wire had a full 12+ volts with the key on, so I thought it would be a good choice to connect to the bat terminal of the distributor. Is this normal with an HEI distributor or do I have something else in the starter circuit wired wrong? Thank you for your help.
Old Aug 29, 2023 | 05:56 PM
bhenders's Avatar
bhenders
MartyJB,
Maybe I am misunderstanding your note ? But I cannot see how you would have the engine start and run in the same key position ? Wouldn't the starter still be engaged if that key position starts the truck ?
Old Aug 29, 2023 | 08:43 PM
dlburch's Avatar
dlburch
check to see if the two small wires on the starter solenoid are switched.
Mar 28, 2023 07:16 PM
Excursion Gary
Nov 21, 2020 08:34 PM
jdhudall
24
May 19, 2017 10:55 AM
460me
Jun 26, 2016 09:27 PM
Ranger GT2
Electrical Systems/Wiring
Aug 30, 2006 06:52 PM
