Highboy which SD front springs
Old Aug 28, 2023 | 04:19 PM
stpackard's Avatar
stpackard
FTE, time to switch out the 1999 berlin eye design front SD springs for some that are heavier duty. Was told diesel SD springs for 6bt.
Early 99-2004 SD gas front leaf spring design
For those of you who have been-there-done-that, what SD spring weights are you running? would X-code SD springs be sufficient?
Reason is going through a 6BT which will take the place of the 4BT.
My understanding was stock 67-77 HD was 2200lb/side. As Xcode (diesel SD) are 2630/, I currently have AFAIK R code (gas SD) which are maybe 1400lb per side. I see a first gen dodge W350 had 1750 or 1900 leaf springs up front. A 6.0 or 7.3 powerstroke is ~950 lbs, the 6bt dodge is maybe 1050lbs.
Appreciatively
Old Aug 28, 2023 | 09:38 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Even though you are a bump side 76-72 guy, we are all here to help out. This is the best High Boy diesel swap thread ever. Maybe the info is in there.
https://www.ford-trucks.com/forums/1...ge+diesel+swap
If you need leaf spring stuff, this is a great place to shop. https://www.autoandtrucksprings.com/...-leaf-springs/
Old Aug 29, 2023 | 07:33 PM
maddogjohnson's Avatar
maddogjohnson
Check out:
https://www.ford-trucks.com/forums/1...e-threads.html
https://www.ford-trucks.com/forums/1...l#post14696881
This might all be the same info in two different threads but the second one has a picture to show the flex you can get.
I've not done the superduty springs so this is all I can share with ya!
kpc3my
Jul 31, 2016 01:22 PM
PAwhiteboy
Engine Swaps
Mar 23, 2013 03:53 PM
crash1
17
Apr 21, 2012 07:25 AM
scatgo
Jan 1, 2009 06:24 PM
beverett2
Offroad & 4x4
Feb 16, 2005 05:46 PM
