Bed cargo lights
Old Aug 25, 2023 | 09:28 AM
USMC/F350's Avatar
USMC/F350
2nd Gear
Bed cargo lights
When I purchased my 2020 F350 Lariat the bed cargo lights worked and they don't. I've looked for fuses and found none. Any thoughts or ideas as I can't see the LED lights on both sides going out at the same time. Thanks
Old Aug 25, 2023 | 09:44 AM
ToMang07's Avatar
ToMang07
I'd start by checking the physical harness under the bed/tail lights. Did you do any changes in Forscan or another scanner? If the harnesses look good you can pull the switch and the lights out to check the connections, but it's not easily done without breaking them.
Old Aug 25, 2023 | 12:16 PM
Fox-BLUE1's Avatar
Fox-BLUE1
When you say looked for fuses, do you mean fuses that identify the cargo lights? I blew a 25 amp trailer tow module battery charge and that took out my bed cargo lights. Replaced it and they work.
k4owb
Aug 25, 2023 07:58 PM
Weston Verhulst
May 5, 2023 08:19 PM
-Doc-
Sep 9, 2007 04:42 AM
53choptop
Mar 20, 2002 11:31 AM
