Ford 390 Cam
Old Aug 24, 2023 | 11:53 AM
FixingFords's Avatar
FixingFords
4wd Low
Ford 390 Cam
Hi guys, I Tried searching the forum because I’m sure this is a common question, but I couldn’t find a way to search just this engine forum. Please help if possible. I am building a mostly stock (will have Edelbrock heads) F250 daily driver that will occasionally (couple times a year) pull 2,500 lbs on a trailer. The transmission is a NP435 and according to the VIN, it has 4:10 gears in the rear. What’s a good cam for this application? I might also be putting a gear vendor behind the transmission, but that will be later on down the road.
Old Aug 25, 2023 | 03:54 PM
'65Ford's Avatar
'65Ford
If I was shopping for a cam, I'd go to fepower.net and provide the same info you just did. They're a bunch of fe nuts and good guys. There are a few guys that really like to talk cams and have built a LOT of fe's. You can get a cam ground that fits your scenario nicely.
While you're at it, consider a roller cam. Eliminates need for break in and eliminates need for high zinc oil. Also, I have a roller cam and after several thousand miles with the high zinc oil and then several thousand with modern oil, I believe I got nearly one more mile per gallon using the modern oil...both were 10w30..
ramarado
Apr 20, 2008 11:46 AM
76F150390ci4x4
Jan 23, 2008 04:59 PM
oldeiron
Nov 17, 2005 08:40 PM
my48willies
Jun 16, 2004 11:13 PM
OLD-F-250
Mar 25, 2004 11:19 PM
