Brake light interruption switch Q
Old Aug 24, 2023 | 08:48 AM
Joe T's Avatar
Joe T
My 2017 is at a shop and I want to do this instead of ravelco misc. hide it under the dash.
Its push button start. I understand this will keep a thief from getting it in gear or started.
Open to PM as well if someone doesn’t want to post it public.
Which wire would I switch? Shop guy has never done this and don’t need any experimentation!
Old Aug 24, 2023 | 01:10 PM
ifrythings's Avatar
ifrythings
I’m not sure how Ford does it but on the Hyundai we have, if you hold down the start button for 10 seconds it will override the brake switch and start, then you can use the shift lock override hole to get it into gear.
I’m guessing Ford probably has something similar incase the brake switch fails, not sure as I don’t have that option.
Old Aug 24, 2023 | 09:45 PM
Joe T's Avatar
Joe T
I want to bypass it to a switch. So I can use it as a kill switch but also use auto start.
Old Aug 24, 2023 | 10:51 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I heard from someone here that pressing the start button for 5-6 seconds would start the truck even if your foot was off the brake (making your switch useless). However, they wouldn’t be able to put it in gear without manually releasing the plunger in the column, which every criminal knows is there.
A hidden switch for the fuel pump or other vital relay would be better.
sddaltongang
Feb 12, 2023 04:58 AM
Unsung
Dec 10, 2020 03:08 PM
wirelessengineer
Oct 24, 2017 07:54 AM
rghouse
Oct 15, 2017 05:47 PM
steeleygreg
18
Feb 23, 2017 09:01 AM
