Stuck brake booster
Old Aug 19, 2023 | 05:59 PM
Mordecai246's Avatar
Mordecai246
7th Gear
Stuck brake booster
I’m trying to swap the brake booster on my 86 f150 but can’t get it to budge. I removed the 4 bolts on the back and was wondering if I’m missing any fasteners or if I just need to pet some penetrating oil on it for a couple days.
Old Aug 19, 2023 | 07:05 PM
Franklin2's Avatar
Franklin2
4 bolts, vacuum line, and the pedal linkage. That should be it. Get a big screwdriver and hammer, get the screwdriver on the edge of the booster bracket and drive it inbetween the bracket and the firewall to force it off.
Old Aug 19, 2023 | 08:46 PM
Mordecai246
7th Gear
I have all that disconnected so I’ll try to force it with a screw driver. Thanks for the help.
Old Aug 19, 2023 | 11:14 PM
kr98664's Avatar
kr98664
Have a helper press on the brake pedal. Loosely install a couple of nuts so the booster doesn't fly off when it comes loose. Tap the booster with a mallet as needed to persuade it away from the firewall.
Old Aug 20, 2023 | 08:50 AM
Mordecai246
7th Gear
I got it off after soaking it over night with some penetrating fluid and prying it off with a screw driver. Thanks for the help.
TheCoach
Oct 22, 2019 01:00 PM
Doc
1997 - 2003 F150
May 29, 2013 08:47 PM
raerjim
Apr 17, 2013 06:02 PM
gtuttle
May 5, 2009 01:06 PM
78 Ranger
Dec 31, 2005 01:59 AM
