Sponsored by: Kumho
brake booster leaking
Old Dec 26, 2005 | 01:31 PM
78 Ranger's Avatar
78 Ranger
the brake booster is leaking in 78 ranger and i can hear it when i shut the engine off for about 10 seconds. what i need to know is if the booster from an 89 f-250 will fit my 78 f-250 and what kind of job it is to replace the booster
Old Dec 29, 2005 | 10:44 AM
73Custom's Avatar
73Custom
Look up part numbers for both pickups and see if they match - I doubt they will. Replacing the booster is easy. Unbolt the master cylinder (leave lines attached) and pull it out of the way. The unbolt rod from brake pedal. Remove 4 bolts attaching booster to firewall. Then you may need to swap the mounting bracket over to the new booster.
Marty
Old Dec 31, 2005 | 01:59 AM
bob arrington's Avatar
bob arrington
if they look the same externally , it should work. an 81 1/2 ton 4X4 booster bolted right up to my 76 1 ton 2X4, bob
