Champion radiator query ............
Old Aug 22, 2023 | 11:03 AM
Slash32's Avatar
Slash32
3rd Gear
Originally Posted by Christmas
That's why I'm glad after 3 4 rows they stepped in and said a 2 row will work better. I was always of the opinion that more rows had to be better, not true.
Thats good to know, if this 3rd 3-row radiator goes TU then I’ll go back to 2-row radiator as well.
Old Aug 22, 2023 | 02:34 PM
tbear853's Avatar
tbear853
Thanks to all who replied.
Exactly the kind of feedback I was looking for in this short thread. If I ever need another replacement, maybe then I'll go aluminum. All this talk of several returns gives me the "*******" .
I've pretty much decided that I'm gonna play this one out, if it ever leaks at the same place, I'll work on it again then ... Dremel tool will work with more J B Weld if needed. It has 3" wide top tank and 2" of core, I forgot to look down inside and count rows before refilling it but it's always been enough.
Aluminum is pretty ... but pretty might clash with what else is under the hood. I will keep my eyes open though, might be I find a back up?
Old Aug 23, 2023 | 02:58 PM
tbear853's Avatar
tbear853
Today, I pulled it around to do some odd things, and to get it good and warm to test my fix. It got warm, then I see two places dripping.
Disghusted, I shut it off, crawled under for a look, coming from up high. Awe man, gonna need a radiator after all.
Tracing green trail led me up and across the upper seam ... right to the new radiator cap, I checked, it was only tightened to the safety notch.
Grab a wrag, press, turn, rinse green off, no leaks no more.
I forget exactly why I did, but I do recall leaving it like that a couple days ago.
I didn't mean to leave it like that, but I did it with the intent to fully turn it before going back in the house ... but I just forgot to is what I mean.
Old Jun 20, 2024 | 10:37 PM
tbear853's Avatar
tbear853
Originally Posted by tbear853
Are they any count?
Yesterday I found a "pinhole leak" peeing coolant out through the grille, no doubt but that it was my fault when I was pulling the AC condenser last week. I removed the grill for access, drained the coolant, cleaned it to metal (copper), l located the hole, little sanding, used muriatic acid followed by carb cleaner, built it up with original J B Weld, included an embedded metal mesh for extra strength, likely it'll hold. It's gonna be well cured by tomorrow, when I'll paint and refill and etc. I put this radiator in when I put the AC in in the late '80s, it has never had "just water", truck has only ever had a 50 / 50 or richer mix green concentrate / distilled water in it since '86. ..........
Post #1 above August 2023. Pic of fix post #5. Just an update for anyone wondering about J B Weld and copper radiator leaks. It might leak tomorrow, but as of today... the J B Weld has been fine.
When I first found that leak I had driven to a friend's shop for some reason and he asked about the paint, I turned to say something and my truck was peeing a strong stream out the grille. The buddy was who suggested the J B Weld, he has done it on his drag car when away from home.
Anyway, it worked for me.
Old Jun 20, 2024 | 10:39 PM
tbear853's Avatar
tbear853
Wife come over to say goodnight, I double posted.
Old Dec 27, 2025 | 07:43 PM
tbear853's Avatar
tbear853
I see where ..... etc .....
Just checked, complete cool down now ... no leak.
It maybe ain't pretty though.
Update 02-14-2024: Still dry
.... fingers crossed too. I still can't believe I did that.
And here at the tail end of 2025, JBW is still holding.
vettman
Mar 17, 2023 08:32 PM
el nino1234
2015 - 2020 F150
May 22, 2019 01:31 PM
Adam.34
Aug 5, 2015 05:37 AM
tyler.dunn94
Jul 10, 2015 08:11 PM
Eallend7
Nov 8, 2012 05:48 AM
