Sponsored by: Real Truck
Spark plug fighting me. (VIDEO)
Old Jun 28, 2014 | 02:57 PM
Hotpocket's Avatar
Hotpocket
All other 7 came out no problem.....but one spark plug is siezed.. luckly it is in the front,,.i have tryed soaking for hours now and it wont budge...One of the plugs was actually so loose i didnt need a ratchet...just turned it by hand. Any suggestions on getting it out?
Old Jun 28, 2014 | 03:49 PM
Bigpipes 35's Avatar
Bigpipes 35
When I click on the video it says it is private...
Old Jun 28, 2014 | 03:58 PM
Hotpocket's Avatar
Hotpocket
I believe i fixed it
Old Jun 28, 2014 | 04:10 PM
Wolfboro's Avatar
Wolfboro
Is the spark plug wrench fitting on the plug ? did you blow out the sand and road debris out of hole ? did you use PB Blaster or similar type rust remover overnight ?
If you have already done all of the above , then you may want to re-examine the plug closely (with a bore scope ) see if there has been a previous "thread repair" ( like Dorman kit , a non-standard spark plug ) . Hang in there .
Good luck,
Old Jun 28, 2014 | 04:11 PM
Bigpipes 35
Have you tried tightening it a little then loosing a little and working it that way..
Old Jun 28, 2014 | 04:27 PM
Hotpocket's Avatar
Hotpocket
The socket fits perfectly...I am using pb blaster and it has been soaking about 8 hours...i blew out the hole with a can of air...My truck has never blown a plug. I am tightening and reversing with my little impact hoping the vibration will help.. It has about 350 ft/lbs of torque but i only go full throttle for a second for fear of breaking it off and it wont budge.. I am trying again about every hour...on a side note the truck runs awesome since i replaced 7 plugs and 8 new accell coils. Im ready for that ohio hill
Old Jun 28, 2014 | 04:29 PM
Hotpocket's Avatar
Hotpocket
I even tryed with the engine at operating temp with no luck.
Old Jun 28, 2014 | 04:32 PM
Bigpipes 35
I guess I would soak it with PB overnight and see if that helps..
Old Jun 28, 2014 | 04:37 PM
Hotpocket's Avatar
Hotpocket
Well the hole is full of pb blaster, it flys everywhere when i impact...i guess i will try again tomorrow.
Old Jun 28, 2014 | 04:46 PM
DavidB's Avatar
DavidB
Forget the little impact wrench. Use a 1/2 in drive ratchet. Make sure that you are holding it straight and pull....hard.
Old Jun 28, 2014 | 05:31 PM
Hotpocket's Avatar
Hotpocket
I'm scared to
Old Jun 28, 2014 | 06:34 PM
Hotpocket's Avatar
Hotpocket
I think my little impact has more than enough power to get job done, I build a lot of chain link fences and it has no problem shearing off nine sixteenths bolts if you aren't watching with your doing
Old Jun 28, 2014 | 06:43 PM
Bigpipes 35
Originally Posted by Hotpocket
I'm scared to
I would be to, if it snaps you are SOL, Leave it overnight and try again tomorrow..
Old Jun 28, 2014 | 06:50 PM
Hotpocket's Avatar
Hotpocket
I agree my friend
Old Jun 28, 2014 | 06:57 PM
Hotpocket's Avatar
Hotpocket
I re installed the coil because i had to drive about 100 miles today but im gonna pull the coil back out and fill the hole back up with pb for the night.
