Is this normal?
Old Sep 17, 2023 | 02:56 AM
KoreanFord's Avatar
KoreanFord
Is this normal?
Hi everyone. I got a 1993 Ford f250 7.5 4wd XLT extended cab and long bed. I ride the truck maybe about only 500 miles a year or so. Im having an issue with a popping noise going over some bumps sometimes and while I turn my steering wheel to the ride. I replaced the whole tie rod and pitman arm set and the noise still continues. I can't quite remember if the noise was there before I replaced the tie rods or not. I recorded a video of the current ones I have installed. I regreased them just in case and made sure everything was tightened. The tie rod seem to rotate pretty hard making a slight bang sound. Can anyone tell me if this is normal or if this is the cause of the noise?
https://youtu.be/azWYKSjGCms?si=ZvzZ67YCTdg3NTy0
Old Sep 17, 2023 | 08:23 AM
mackendw's Avatar
mackendw
I'm betting it's the body mount bushions being dried out. I used some AmSoil HD spray on mine and they quieted down quite a bit.
Old Sep 17, 2023 | 08:26 AM
sandymane's Avatar
sandymane
I need to be somewhere soon so I don't have time to properly answer your problem. DO NOT DRIVE THAT TRUCK NOW. WAIT TILL SOMEONE HELPS YOU.
Old Sep 17, 2023 | 03:39 PM
manicmechanic007's Avatar
manicmechanic007
Check into the "huck" rivet popping issue that we techs fixed thousands of (TSB)
Used to get paid by the rivet and the big one at the rear of the steering gear is the Huck one they called it
A hole techs used to just weld the frame which was a bad no no
Did weld one myself still waiting to get sued for
Old Sep 17, 2023 | 03:41 PM
manicmechanic007
You have to get damn serious to get that huck rivet out and replace it with the special bolt
Old Sep 17, 2023 | 04:02 PM
mackendw's Avatar
mackendw
this:?? https://www.f150forum.com/f10/warnin...arning-107573/
Old Sep 17, 2023 | 04:17 PM
manicmechanic007
I'm not sure why that particular Huck rivet is so big and robust
I have never heard of one getting as bad as the one mentioned in that post
Usually they just pop once in a while when turning back and forth, and after getting looser still, it will pop every time you turn the wheel back and forth.
We used to test for loose rivets with white out typewriter mistake stuff
Paint it on there, let it dry and drive the truck
When back from the test drive, check for broken white out paint around the rivets
Old Sep 17, 2023 | 04:36 PM
mackendw's Avatar
mackendw
in the video the korean guy posted illustrating the popping noise, all I see is the tie rod ends moving/popping when enough force is applied during turning motion. These are all held on with bolts/nuts...
where is the big rivet?
KoreanFord
Jul 20, 2021 12:55 AM
Toneloc44
1983 - 2012 Ranger & B-Series
Nov 30, 2012 09:34 AM
Msp541
Nov 3, 2005 08:37 PM
Eddieslilmule
1997 - 2003 F150
Nov 20, 2003 12:10 AM
