Trailer Wiring Module Fault
Old Aug 14, 2023 | 08:25 AM
WXboy's Avatar
WXboy
Hooked a trailer to the new-to-me '19 F-250 this weekend and none of the lights would work. Got a message on the dash "trailer wiring module fault" and then "left turn signal fault". Checked all the fuses that control trailer lighting. All OK. Pulled apart the 7-pin connector at the bumper and cleaned it well and applied dielectric grease. Reassembled. Now trailer lights and brakes work 90% of the time but occasionally while driving the same error messages pop up, then disappear, then pop up again randomly.
This trailer's lights and brakes work perfectly 100% of the time on my Dad's GMC and my cousin's Ram. So it's not the trailer. Are these Ford trucks that finnicky? What do I need to try next?
Old Aug 14, 2023 | 09:18 AM
senix's Avatar
senix
does the truck would as it should with other trailers? I would try that next.
Old Aug 15, 2023 | 09:34 AM
Mike Bartlett's Avatar
Mike Bartlett
Try a bigger ground wire from your trailer. You could rig up a temporary from the trailer frame to the truck chassis maybe with jumper cables. I had something similar with my 2019.
Mike
Old Aug 15, 2023 | 10:12 AM
MAX4utah's Avatar
MAX4utah
My 22’ does this as well. I have not pursued a fix yet. I was going to have the dealer re-flash the brake controller next time I’m there.
Old Aug 15, 2023 | 12:17 PM
Don Ridley's Avatar
Don Ridley
Does the trailer have LED lights? There is a setting to switch between standard and LED trailer lights.
Old Aug 15, 2023 | 01:35 PM
WXboy's Avatar
WXboy
The trailer I was towing this past weekend has incandescent bulbs.
My enclosed trailer is LED. I'll have to check that out.
Ridiculous that it can't just WORK like with every other truck out there. Never had one seconds trouble with LED or standard lights on a trailer with my Ram or my father's GMC.
Old Aug 15, 2023 | 01:52 PM
seventyseven250's Avatar
seventyseven250
Strongly suspect grounding issues on the trailer or the 7-pin connector.
Old Aug 19, 2023 | 10:30 PM
154incher's Avatar
154incher
6th Gear
Had same problem with my 2022. I spent the 50-75 bucks for a new 7 pin bumper receptacle and problem was solved.
steelie green
Apr 15, 2021 03:30 PM
cgm73
Oct 13, 2019 07:35 AM
Exposed
All Things Towing
36
Aug 18, 2019 12:06 PM
slip knot
Nov 24, 2018 03:37 PM
13Raptor
2009 - 2014 F150
Apr 3, 2017 12:20 PM
