62 Uni Generator to Alternator Conversion Question
Old Aug 14, 2023 | 07:33 AM
Road_Tripper's Avatar
Road_Tripper
My system isn't charging, so I am thinking I should probably upgrade to a 1 wire alternator. Anyone have recommendations for a good alternator to buy? I have a 62 unibody with a 223 and is there anything else I need besides the alternator?
Old Aug 14, 2023 | 08:02 AM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
You’re going to need brackets. I did it on my old Y-block, your I-6 will be different. You should read through this thread. :
https://www.ford-trucks.com/forums/1...onversion.html
Make sure that the new alternator pulley lines up properly with the pulley on your engine.Good luck.
Old Aug 17, 2023 | 07:55 AM
BobbyFord's Avatar
BobbyFord
I have a 3 wire 10SI on my Uni. Gen light works as designed. I currently have the truck apart, going to go with AAW wire loom. I might upgrade to 3G. I have 3G on my 72. Both trucks have electric fans.
Old Aug 20, 2023 | 06:40 PM
Thunderkiss1965's Avatar
Thunderkiss1965
If you value the original look, there is a company making a one wire, internally regulated alternator in a generator case. I put one in a 64.5 mustang a couple weeks ago. Of course I can't bring up the name of the company it came from but I can find out when I go to work tomorrow.
Old Aug 20, 2023 | 07:21 PM
BobbyFord's Avatar
BobbyFord
…but a one-wire won’t allow a functional “gen” light. A 3-wire will.
Old Aug 20, 2023 | 09:37 PM
Thunderkiss1965
I misspoke. It can be run with only one wire but it does have a ground post and a voltmeter post, in the same place that the gen has posts.
I stand corrected.
Old Aug 21, 2023 | 02:14 PM
resonateur's Avatar
resonateur
Powermaster makes an alternator which has the appearance of an original generator. It's a one wire....so to speak. Still needs a good, large gauge ground wire and there's a model that has a post to connect to your generator light on the dash. The model line is called PowerGen. Go to their website for particular model numbers and features. The ones with the suffix ("S", I believe), are those that have the feature for the gen light on the dash. They're much more $ than a generic alternator, but look nice and work well. And advantage, if you have an original generator, it will use the same brackets.
Old Aug 21, 2023 | 03:09 PM
Thunderkiss1965
Yes, Powermaster is the one I installed. I was an easy install and worked just fine.
Old Aug 28, 2023 | 03:50 PM
Road_Tripper
Thanks Everyone!!
Looks like summit sells them and at the bottom they call out "Ford swing mount designed to fit generator brackets. Has indicator lamp terminal." so sounds like the right one
https://www.summitracing.com/parts/p...-100/year/1962
Old Aug 28, 2023 | 04:54 PM
Grampa69's Avatar
Grampa69
Wow. I thought about this conversation but think I'll have to postpone. That's pricey, maybe worth it when needed. Last time I bought an alternator, they were about a dollar an amp.
Old Sep 1, 2023 | 10:26 AM
Road_Tripper
You can get a lower cost one if you aren't worried about keeping the generator look
I also found this one for $109
https://www.summitracing.com/parts/sum-810308
Old Sep 3, 2023 | 11:36 AM
Rad082625's Avatar
Rad082625
Vintage Auto Garage has a bracket that mounts the alternator using the existing generator bracket for around 60 bucks. You can get rebuilt 60-80 amp Delco alternators for under 100 bucks all day long. The alternator options these guys are talking about are too rich for my blood....Bob
Old Sep 10, 2023 | 11:07 AM
Road_Tripper
I looked on that site, but wasn't having any luck finding something low cost
Old Sep 12, 2023 | 08:00 AM
Rad082625's Avatar
Rad082625
Wow. If that stuff is too expensive study the pictures closely and fab your own brackets, if you can afford the steel that is?
Old Sep 12, 2023 | 12:59 PM
Road_Tripper
The stuff I was finding on vintage auto was around the same prices I was finding on Summit so not sure where you are finding those prices you are referencing. Can you share a link or point us to where you are seeing them?
