Dash wiring identification
Old Aug 13, 2023 | 06:38 PM
Dr. Johnson's Avatar
Dr. Johnson
So in the process of fixing some wiring misroutes I found this big flat plug toward the top of the wiring behind the instrument cluster (this flat plug sits on top of the harness that t’s off the ignition switch.
my question is, what is it? There are two wires that just loop. A RED/BLUE wire and a BLACK/ORANGE wire.
1970 F250
manual trans
Old Aug 13, 2023 | 10:52 PM
Green72F250's Avatar
Green72F250
I think that is your Neutral Safety Switch bypass connection, beings your truck is a manual transmission. Here is an article that talks about it:
Neutral safety switch don't work now? - The FORDification.com Forums
Old Aug 14, 2023 | 12:04 AM
Phantomtruck68's Avatar
Phantomtruck68
Here is wiring diagram. http://fordification.com/tech/wiring...-70_master.jpg
Look center bottom of diagram by the dimmer switch.
Old Aug 14, 2023 | 12:07 AM
Dr. Johnson
I think you nailed it, sure looks like the critter. Wonder if a guy could steal switched power from that line? 🤔
Old Oct 5, 2023 | 12:42 AM
1968F250429's Avatar
1968F250429
nope, one side is crank only and the other is for the reverse lamp circuit I believe. I know without that jumper it won't start.
Syphlyn
May 8, 2020 12:37 PM
1979bronco
Electrical Systems/Wiring
Mar 21, 2014 12:36 PM
big_super_duty
Apr 28, 2011 06:25 PM
Rust is too a color
Jul 20, 2010 11:10 AM
medicpg
Aug 23, 2003 09:04 PM
