wiring help needed
Old Jul 15, 2010 | 03:19 AM
Rust is too a color's Avatar
Rust is too a color
Cool wiring help needed
Does anyone have any advice on how to determine the correct wiring position to the 8 leads on the headlight switch? The factory harness plug has been removed and now its an 8 wire guessing game. I think there are 40000 possibilities. Perhaps someone can snap a good clear pic of their plug and by some miracle, I might have the same colored wires. The only thing I know for sure is that I have 2 wires that are hot and one is hotter than the other. ANY ADVICE, PLEASE!!
Old Jul 15, 2010 | 06:39 AM
baracade's Avatar
baracade
Good luck, I tried for 3 months to find the wiring diagram for the ignition switch for my 66, finally got lucky and found a wrecked 64 with the ignition switch pigtail still intact!
Old Jul 15, 2010 | 09:35 AM
daveengelson's Avatar
daveengelson
Sorry, bout only help I may able to provide is copy of the circuit from the wiring manual, color codes may not be correct but possibly provide indication of wires general direction.
http://i300.photobucket.com/albums/n...WireDiagP7.jpg
Old Jul 15, 2010 | 01:44 PM
friskyspatula's Avatar
friskyspatula
I have been working on some wiring issues as well on my 64. I found a place that had the entire wiring diagram that can be downloaded.... it is a pretty big file so I can't post it, but here is the link:
1964 ford truck F-100 wiring diagrams.zip
I hope it helps.
Matt
Old Jul 16, 2010 | 06:39 PM
Rust is too a color
Thanks guys, those both helped a bunch. I also found this on a Mustang site called stangnet. Its identical for the '66 F100.
Old Jul 18, 2010 | 07:32 PM
68torino's Avatar
68torino
I just tried to start my "new" '66 F100 and fried a wire that runs from Alt. to Volt Reg. I figure that shoot I'll just go to Painless for a new harness. Well they don't have one for a '66, so I figure that since a 'stang has same diagram I could get that. Might need to 'stretch' a couple of wires.
DANG! they want $570 for JUST a harness???? No new alt. or starter or switches. Just wires and a fuse block.
Well looks like I pull apart the insulation and do it the hard way.
Old Jul 18, 2010 | 08:01 PM
Broomfieldbum's Avatar
Broomfieldbum
I bought the EZ-Wire Kit with 18 Circuits for $200.00 go to Golden RODtronics | For All Your Electronic Needs, and talk to Dave he will set you up with a EZ-wire kit that has the wires marked every 6 inches with what they are. Really easy to install, and no a bad price. He also has a 12 circuit one for a little less.
Old Jul 18, 2010 | 08:47 PM
daveengelson
Opp's, see where another source has been posted.
Old Jul 20, 2010 | 09:55 AM
68torino's Avatar
68torino
Thanks! Wasn't so much the price per say, except my 'ready' money is going to a new comp. To my mind I would prefer redoing all the wires instead of ending up with miles of black tape "bandages".
Old Jul 20, 2010 | 11:10 AM
daveengelson
Purchased set of reproduction harnesses few years ago for the 65 from Mr. Mustang, Inc., same connectors and wire codes, matter of unplugging the old and plug in the new. Can be expensive; taillight, headlight harness run about $100 ea., the engine harness runs around $50; unfortunately have not found anyone who reproduces the dash harness. Understand few of the Ford part suppliers also carry them, have not priced them. If decide on 'do it yourselfer' suggest using electrical harness wrap, it's non adhesive and does'nt gum up the wiring. Used small plastic ties when I replaced, or repaired wires on the dash harness on the 65, found it easier to keep track of wires.
mooch94122
May 30, 2012 12:52 AM
Austin J.
Mar 16, 2012 07:28 AM
Austin J.
All Things Towing
Mar 15, 2012 03:37 PM
Austin J.
Electrical Systems/Wiring
Mar 13, 2012 10:24 PM
Katy351Cleveland
1978 - 1996 Big Bronco
Mar 3, 2003 10:14 PM
