2002 v10 6.8 excursion ticking
Old Aug 12, 2023 | 12:03 PM
Steverino622's Avatar
Steverino622
3rd Gear
New to the forums recently bought a 2002 ford excursion with the v10 for less than 3k runs good other than a small oil leak I'll be fixing that soon, but what I need help with is when the engine is cold it has a ticking sound/ pinging when idling and when the rpms are raised once it gets up to temp it disappears seems to be coming from driver side as I can hear it when I roll my window down Any thoughts? I have a 4.6 3v and I've owned a couple 5.4 3v so I know the the story's.
when I get off work and figure out how to send videos I'll add it to the thread
Old Aug 12, 2023 | 03:28 PM
2002Ex's Avatar
2002Ex
Check spark plugs for tightness!
Old Aug 12, 2023 | 06:50 PM
projectSHO89's Avatar
projectSHO89
or an exhaust manifold leak, usually caused by broken studs.
Old Aug 12, 2023 | 09:33 PM
Steverino622
3rd Gear
Was looking around in the engine bay noticed this... driver side 5th exhaust port towards the back... havent been able to check spark plugs yet though
Old Aug 13, 2023 | 11:33 AM
R&T Babich's Avatar
R&T Babich
Originally Posted by Steverino622
.... other than a small oil leak I'll be fixing that soon, but what I need help with is when the engine is cold it has a ticking sound/ pinging when idling and when the rpms are raised once it gets up to temp it disappears seems to be coming from driver side as I can hear it when I roll my window down ....
Is the oil leak on the passenger side at the rear of the head?
Ours has a small leak there which drips onto the exhaust, burns and smells, but doesn't reach the ground.
I'm waiting until it gets worse, 40k and still waiting.
I've read it's the head gasket
If you are not sure the spark plugs were torqued to 20 ft/lbs or more, check/tighten them.
When we got our Ex it had 103k on the OEM plugs and blew #3 at 104k.
I was going to change them the next weekend.
An exhaust leak ticking can go away after things heat up, ours has 1 broken stud, but no ticking.
At one point ours was ticking and it would stop after warming up.
I had installed an SPD Y-pipe and one of the pipe connections was loose.
Old Aug 13, 2023 | 01:54 PM
Steverino622
3rd Gear
I'm going to check the spark plugs today it's got 296k miles lol but the coils look brand new wont hurt to check though.. I did see that the exhaust manifold 5th cylinder stud is missing or broken off 😳...
Also the oil leak seems to be rear main seal it's not bad but seeps through
4Kids
Modular V10 (6.8l)
16
Oct 20, 2022 02:00 PM
kystangbanger
Jan 25, 2012 11:50 AM
9402fordguy
Apr 27, 2011 07:42 PM
maxum96
Jan 26, 2010 11:00 AM
PF297G
Nov 9, 2006 07:10 PM
