Steering popping
Old Aug 11, 2023 | 01:17 PM
WXboy's Avatar
WXboy
Steering popping
This Super Duty I bought has 81k on it. While driving, I occasionally feel a pop/looseness through the steering wheel. It's very light/faint. But I can definitely detect it especially on a gravel road. The average person may not notice it. A truck enthusiast would. Almost feels like something in the front end is slightly loose. Someone on here suggested that I go under the truck and grease everything up. I went under the truck and found zero grease zerks. Nothing at all on the sway bar, drag link, tie rod, ball joints, etc. All appears to be non-serviceable joints.
Is this slight pop/looseness normal on these HD trucks? Or do I have something likely failing? Gosh I hope the ball joints are OK....absolutely cannot afford that right now.
Old Aug 11, 2023 | 01:52 PM
scraprat's Avatar
scraprat
Top Answer: 5
Zerk fittings on the ujoints of the front wheels.
Jack the front end up and look for loose parts, look for movement in wheels, up/ down. Shock grommets.
Old Aug 11, 2023 | 06:09 PM
MBuckholz's Avatar
MBuckholz
Check make sure hubs are not locked
Old Aug 11, 2023 | 07:40 PM
honda250xtitan's Avatar
honda250xtitan
i've chased this for ever as well. I've done tie rods, track bar, shocks, steering stabilizer. good luck amigo.
(track bar bolt is supposed to be like 400lbft so that could be a good one to check.)
its very faint, and comes and goes....actually noticed it again this week
Old Aug 12, 2023 | 08:17 PM
WXboy's Avatar
WXboy
So I was watching a video on the 2017 Super Duty when it was debuting, and the guy was talking about how Ford put an electric motor for steering assist inside the steering wheel. I had to rewind because I thought I misunderstood them, but there is a picture of it also. What in the world? I've never seen anything like that before. Is this on ALL Super Duty trucks?? Maybe this is why I've been feeling a looseness through the steering wheel.
Old Aug 12, 2023 | 10:13 PM
4wd6.7L's Avatar
4wd6.7L
Double post
Old Aug 12, 2023 | 10:16 PM
4wd6.7L's Avatar
4wd6.7L
It's called adaptive steering, does your truck have it? It was an option that would be listed on the window sticker.
Edit- it looks like you have an XLT, I don't think adaptive steering was available below the Lariat trim.
Old Aug 12, 2023 | 10:18 PM
StonedGrey's Avatar
StonedGrey
Is this a tapping your feeling in the steering wheel at lower speeds? Also feel it in the throttle pedal?
if thats what it is, your intermediate steering shaft and pass thru bushing at the firewall needs to be replaced.
Old Aug 12, 2023 | 11:06 PM
HarveyTruck's Avatar
HarveyTruck
There’s been a few threads on this, definitely something to check. The steering stabilizer could be shot, there was also a recall on those. Many have upgraded from stock. I had replaced mine with a Rancho 9000 before I ever got the recall notice.
Old Aug 13, 2023 | 01:11 PM
WXboy's Avatar
WXboy
That's what I was thinking. Feels like a steering shaft pop. Years ago I had a truck that had that issue commonly and guys would grease them up and reassemble and it would go away. Hmmm...
Old Aug 13, 2023 | 08:28 PM
StonedGrey's Avatar
StonedGrey
what year and trim level is your Super Duty?
Old Aug 13, 2023 | 08:37 PM
jtoyo007's Avatar
jtoyo007
6th Gear
I had the same popping and it ended up being the drag link or center link. It drove me crazy for months trying to figure it out.
Old Aug 14, 2023 | 08:11 AM
WXboy's Avatar
WXboy
2019 XLT base
Old Aug 14, 2023 | 09:25 AM
Pugga's Avatar
Pugga
I had a popping, turned out whoever did front end work previously didn't tighten up the clamps at the tie rod ends.
Old Aug 14, 2023 | 09:40 AM
scraprat's Avatar
scraprat
Top Answer: 5
So did you actually crawl under and check things out, pop the hood and look at the steering shaft?
