So did you actually crawl under and check things out, pop the hood and look at the steering shaft?
Yeah, had to straighten the steering wheel anyhow. Guy who aligned it didn't get it right. While under there checked it all out. Don't see anything glaring jumping out at me. The steering intermediate shaft looks like a nightmare on this truck. Would have to crawl down into the engine bay to reach it. There are two u-joints in it instead of a slip joint like most I've seen. Odd. Looks like something I don't want to fool with though.
I will crawl under again tonight and see if there are any grease fittings on the axle shafts.
You can check the steering shaft pass thru bearing by grabbing the top and bottom of the steering wheel and push/pull with your hands. If u feel/hear the tapping clicking popping, the. The pass thru bearing/bushing & steering shaft are bad.
replacing it is not too terrible. Not a fun job by any means.
remove the left front wheel well. And the. Access is available. The shaft does collapse and slide into itself. 3 bolts in the pass thru bushing. 8mm maybe. And then 10mm at the top and bottom of the shaft.
the worst part is the wheel well liner bc of all the push pins where the wiring harness is attached.
the track bar bushing on the pax side was worn and would move vertically about 1/8 of an inch. That was the cause of my popping.
I had a clunk or pop on my 2018, but mine issue was at the opposite end of the track bar. My bushing was fine but the ball joint on the track bar was slightly bad. When stopped, if you turn the wheel quick left and right, does it pop/clunk? That's what mine did. Had wife turn wheel back and forth slightly as I was underneath touching each ball joint to check for excess play.
I did that trick with the steering wheel to see if the intermediate shaft bushing may be failing and it is very tight and I don't see anything wrong with it. So now I am suspecting the track bar. I think you guys might be on to something. I know this is a very common issue on Jeeps and Ram trucks with solid front axles and the symptoms really do point to that. So now the question is do I spend my $200 deductible to get the dealership to replace it with a factory one? Or do I spend the $200 on the Rough Country aftermarket one?
I suspect they take your $200 even if that's not the problem?
if you have a plan that covers it, go with the OEM and $200 deductible. The rough country will require adjustment and alignment. The OEM will not.
(if it’s not the bushing but it’s the ball joint, then the trackbar downs need changed at all). I had my shop replace the track bar ball joint with a kryptonite ball joint.
So today I had my son turn the steering wheel back and forth while I was under the truck. The track bar joints are fine. But, the drag link joints have noticeable play at both ends. I can actually watch the joints move up and down as he turns the wheel. The pitman arm end is worse, but the spindle end does have play also.
Makes sense why I feel it in the steering wheel! Looks like I get to use my extended warranty right off the bat.
So on a gas truck it would be a cake walk. On a diesel truck it is harder. What I did was use a lot of extensions connected to reach the two bolts from under the hood. Upper one is 13mm, lower is 10mm. Once the two bolts are loose, I reached through the wheel well and removed the bolts by hand. You have to totally remove both of them. Once you do that, you can slide the shaft out by hand, put the new one in, and get the bolts started again. Then go through under the hood with the extensions on the ratchet to tighten.
Make *certain* that you get the new intermediate shaft all the way onto the main shaft and steering box shaft, and tighten it well. You do NOT want this part coming loose while you're driving.
I shot a quick video when I did it. Not sure if this link is active yet or not, but it will be soon:
May I suggest a little Loctite on the threads to prevent them from backing out during vibration.
Probably not a bad idea if the correct Loctite is used. I didn't notice any thread locker on the bolts from factory installation. So I didn't put any on when I reinstalled. But I may do that soon.
