Clutch for a Frankenstein
Old Aug 10, 2023 | 05:43 PM
Z Martin's Avatar
Z Martin
Hey I have a '66 F100 that the previous owner tried to make a hot-rod out of him. He Swapped in a '70 351 Cleveland with a M5OD-R2 tranny from a 89 F150. I basically I use the truck as a truck with occasional towing. The rig needs a new clutch and hydraulic slave cylinder. My question is which clutch will work with the M5OD tranny and the 351?
Old Aug 10, 2023 | 06:41 PM
85e150's Avatar
85e150
What's in it now?
Possibly the whole stock 351C clutch or a 351C pressure plate with a disc for the splines on the M5OD.
Old Aug 10, 2023 | 08:33 PM
Z Martin's Avatar
Z Martin
What's in it now?
Not exactly sure I plan on tearing into it this weekend.
Old Aug 20, 2023 | 10:28 AM
Z Martin's Avatar
Z Martin
I think the clutch is still good, I suspect the salve cylinder thingy. When I start the truck in the morning the clutch engages at the bottom of the pedal yet after one or two applications the clutch doesn't grab until all the way at the top. Is this typical of a bad slave cylinder in the M5OD? Sorry if the question seems dumb but I have never had a vehicle with a hydraulic clutch.
Old Aug 20, 2023 | 12:40 PM
Crop Duster's Avatar
Crop Duster
You need to crawl around and check for leaks. If it's not leaking, then bleed the thing. Go over to the 89-96 forum and do a search for bleeding hydraulic clutch..
Old Aug 20, 2023 | 01:03 PM
Z Martin's Avatar
Z Martin
ok will do
Z Martin
Feb 14, 2023 09:28 AM
Paramedpete1996F250
Dec 11, 2008 07:43 PM
woody42
Dec 5, 2008 08:51 AM
Burris1974
Oct 29, 2003 04:36 PM
