Removing the intake manifold
Old Aug 9, 2023 | 03:11 PM
daveengelson's Avatar
daveengelson
On my 65 F100, with a 390, many years ago I swapped the aluminum Edlebrock single plane intake manifold for the cast iron Ford 4bbl thinking I would increase MPG, oh well live and learn? After setting for some time I now want to clean and dress the engine but appears the rocker assembly needs to be removed in order to do so; faced with the dilemma whether clean and paint the intake as best as possible while on the engine or deal with removing the rocker assembly, appears assembling and adjusting the valves can be labor intensive task I just do not recall having to so in the past nor what is involved? Possibly selling after installing the engine, assembling new front suspension and making a few minor repairs??
Comments/Suggestions appreciated!!
Old Aug 9, 2023 | 03:37 PM
AZSCAWPION's Avatar
AZSCAWPION
You didn't mention that you also previously changed the rocker assemblies so, figuring that you've kept the stock originals, they are non adjustable. Just remove and replace as they were.
Old Aug 9, 2023 | 06:39 PM
6t6merc's Avatar
6t6merc
With #1 cylinder at firing position, turn the engine by hand a little clockwise to put the pointer on the XX on the balancer. Loosen the shaft bolts 1/4 turn, starting from #8 cylinder and from #1 cylinder. Remove the shafts, remembering where the reduced-shank bolts go. Pull the pushrods and keep them in order. Be sure no lifters come out. Reassemble in a similar way. No valve adjustment will be necessary, even with adjustable rockers, if nothing is disturbed or mixed up. (The pushrods are not necessarily all the same length.)
Sounds like the motor's out. Good time to remove the water pump for a new bypass hose, and install the pump after the intake.
Eric.
Old Aug 11, 2023 | 05:38 PM
daveengelson
As a result of U all's comments and suggestions it will be a 'do it myself' project I will have to minimize my senior moments and focus on what I am doing. I thank U all's for the help!!.
Old Aug 11, 2023 | 06:31 PM
spurredon's Avatar
spurredon
Those cast intakes are nearly as heavy as the block! You might want a hoist! LOL! These days I would need one.
Old Aug 11, 2023 | 06:51 PM
daveengelson
Watched a video, believe it was 'Roadkill' where the team replaced a cast iron intake with an aluminum where the cast iron came in at around 75 lbs and the aluminum at around 35 lbs. My experience is if I am running a 390 gas hog swapping the aluminum 4bbl open single plane intake for the cast iron was not worth perhaps the 2 mpg increase. .
Old Aug 12, 2023 | 06:17 PM
spurredon's Avatar
spurredon
That's a good point. Look at all the work you just saved yourself!
Old Aug 12, 2023 | 08:40 PM
6t6merc's Avatar
6t6merc
My latest swap is still fresh in my mind. I had things apart for lifters so I removed a minty Streetmaster and put on an "S" iron intake. I had blocked the crossover on the Streetmaster mainly to prevent corrosion. It seemed never to warm up without the exhaust heat. It now runs way better in all conditions and makes usable power from 1000 rpm too. Dunno about the mpg... pretty bad either way.
Eric.
GermanMike
Modular V10 (6.8l)
Jul 24, 2012 09:18 AM
mikepn
Bronco II
Feb 21, 2004 08:16 AM
pigsew
Aug 19, 2001 06:08 PM
stevieboy
Jan 13, 2001 11:44 AM
