Help Identifying the Last Wire-Engine Harness
Old Aug 8, 2023 | 10:30 PM
SVandal's Avatar
SVandal
I swapped a 99 7.3 into my 97 and kept the newer oil reservoir and HPOP and fuel bowl. I’ve been able to identify all but one wire. It is Red w/white stripe and goes to a 90deg push on. It’s not for the fuel bowl and I can’t find any other place for it. It goes to pin 31 in the engine harness plug. Does anyone know what this is supposed to connect up too?
Old Aug 8, 2023 | 10:46 PM
z31freakify's Avatar
z31freakify
Oil pressure switch or water in fuel connector.
Old Aug 8, 2023 | 10:52 PM
SVandal's Avatar
SVandal
I’ve gotten both of those. Oil pressure (top of HPOP) was white w/red stripe and water in fuel was red w/black strip.
Old Aug 8, 2023 | 11:12 PM
96SD's Avatar
96SD
Coolant temp sensor?
Old Aug 8, 2023 | 11:53 PM
SVandal's Avatar
SVandal
Thank you. Thats the one. I hooked up the white/blue to the water pump sensor. I didn’t realize I need to add a second sensor to the block since I changed it to a manual transmission.
red/white - sensor on top of water pump
white/blue - sensor on front, passenger side of the block.
Rob89
Jun 27, 2021 10:55 AM
lou78
Jan 23, 2019 10:58 AM
ChrisMelton78
May 24, 2016 12:14 PM
blackf3504dr
Sep 13, 2011 02:03 PM
70T351W
Feb 21, 2007 08:42 PM
