Unidentified bell housing
Old Aug 8, 2023 | 12:32 PM
Rollingscrapmetal's Avatar
Rollingscrapmetal
does anyone know what this goes to numbers on it are c7ta 7505 I thought it was a 302 but only the 2 opposite the starter lined up
Old Aug 8, 2023 | 12:42 PM
Rollingscrapmetal
For a bit of context it had a 1-3/8 input shaft attached to it so not a transmission just some sort of power output and it was found it was in the middle of the desert with a 90s ford ac unit in the trash pile
Old Aug 8, 2023 | 02:18 PM
RichS2659's Avatar
RichS2659
As the 240/300's are SBF pattern, they were plentiful in all kinds of power products like power units, pumps, N H balers, NH combines, etc.
Old Aug 8, 2023 | 02:56 PM
Rollingscrapmetal
Are you saying it's off a 6 cylinder because I thought they shared a bell housing with the 302
Old Aug 8, 2023 | 05:08 PM
85e150's Avatar
85e150
They do share the six pattern so I can't explain any difference. Have you compared them side by side?
Here is a bell with the same numbers--although you don't list the last "A" if you have it. Lots of pics and usage listings:
https://www.ford-trucks.com/forums/9...el-clutch.html
Old Aug 8, 2023 | 11:50 PM
RichS2659's Avatar
RichS2659
I don't think 302/351W's were used as industrial engines until the late 80's used as boat engines. The Sixes were used as industrial engines due to great gobs of torque produced compared to a V-8.
Old Aug 12, 2023 | 02:14 PM
Rollingscrapmetal
It's close but it isn't the same pattern as a small block
Old Aug 12, 2023 | 03:51 PM
yardbird's Avatar
yardbird
The other housing could be from an FE on a 1964 and earlier because of what appears to be a narrow transmission bolt pattern, and the big hole for the clutch release rod.
Old Aug 12, 2023 | 04:30 PM
85e150's Avatar
85e150
It's got a 1967 casting code.....
Old Aug 12, 2023 | 05:14 PM
Rollingscrapmetal
The other ones a 390 and went to the np435 sitting on that small block
Does an industrial 300 have a different bell housing pattern maybe that could be it. That linked thread mentions his was attached to a 300 with a 184 tooth flywheel
Old Aug 12, 2023 | 07:21 PM
85e150's Avatar
85e150
See the link in post 5. There is only one pattern for the 240/300. That link shows a bunch of adaptors etc.
Old Aug 13, 2023 | 06:13 PM
1TonBasecamp's Avatar
1TonBasecamp
It sure does remind me of some kind of a pump housing flange.
What other truck engines were available in 67? What bolt pattern does a 352, or one of those other engines that was only found in the heavy trucks have?
I know there are plenty of Ford engines that I’m not familiar with.
Some of which I may never even have seen!
Old Aug 14, 2023 | 07:36 AM
fe390pc's Avatar
fe390pc
I am going to take a stab at this, since it has mounts on it I believe it is for a "Y" Block 292 or 312.
Old Aug 15, 2023 | 01:16 AM
RichS2659's Avatar
RichS2659
1964 was the last year for a Y block so no dice on that one.
The cast ID number is 7505-A so it is from post #2 of the other thread from ND here below:
C5TZ7505E .. Bell Housing / Marked: C5TA-7505-A or C7TA-7505-A.
Fits: 1965/69 B/C/F/N500/600 240/300 / Use with 4 Speed Manual Transmission.
Fits: Same as above with 5 Speed Manual Transmission.
Fits: 1970/72 B/C/F/LN500/600 240/300 / Use with Warner T-19 (4 speed); Clark 280V (5 speed); New Process 435 (4 speed) & 542 (5 speed) Tranmissions.
Old Aug 15, 2023 | 06:02 PM
kenny nunez's Avatar
kenny nunez
Bell housing
The one on the left is from a 292 “Y” block truck with a hydraulic clutch.
